查看: 206|回复: 6
jake before brakes i80 wb from reno
 楼主| 发表于 2020-2-13 10:00:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"been seeing way too many truckers not using them an just riding the brake ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":3040.0,\"name\":\"\",\"url\":\"\",\"width\":1440.0},{\"description\":\"\",\"height\":3040.0,\"name\":\"\",\"url\":\"\",\"width\":1440.0}]","canComment":true,"externalShare":false}
发表于 2020-2-14 10:49:43 来自手机 | 显示全部楼层
917683 发表于 2020-02-14 02:47:38 Hey now,  when I started with Steven's back in '97 they had the jakes disconnected.   You don't need jakes to descend a grade ( yes, they help ) proper gear and braking technique is all you need.  What happens if you're relying on your Jake brake going down a grade and for whatever reason they cut out? I'd rather rely on downshifting and stab breaking.
","text":"Unfortunately they don't teach that anymore.  I agree with you though ","replyToPid":325946}
发表于 2020-2-13 11:12:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"He went full rètard. \n\nNot retarder. ","replyToPid":0}
发表于 2020-2-13 16:44:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"they may have been on the Jake brake ....my brake lights come on with the jakes","replyToPid":0}
发表于 2020-2-14 04:13:54 来自手机 | 显示全部楼层
235536 发表于 2020-02-13 08:44:30 they may have been on the Jake brake ....my brake lights come on with the jakes
","text":"mine do too. I get tired of people telling me to get off the brakes when I'm not even touching them","replyToPid":325506}
发表于 2020-2-14 04:25:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Anyone who goes down Donner without using the jakes are full fledged idiots ","replyToPid":0}
发表于 2020-2-14 10:47:38 来自手机 | 显示全部楼层
674254 发表于 2020-02-13 20:25:14 Anyone who goes down Donner without using the jakes are full fledged idiots
","text":"Hey now,  when I started with Steven's back in '97 they had the jakes disconnected.   You don't need jakes to descend a grade ( yes, they help ) proper gear and braking technique is all you need.  What happens if you're relying on your Jake brake going down a grade and for whatever reason they cut out? I'd rather rely on downshifting and stab breaking.","replyToPid":325692}
GMT+8, 2026-2-15 16:30 , Processed in 0.061895 second(s), 24 queries .
