查看: 314|回复: 7
Personal convenience driving after drop off.
 楼主| 发表于 2020-2-13 05:11:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi guys, I’m little bit confused, please assist:\nI will drop off my empty trailer at amazon and after that I would like go to nearest truck stop(6 miles, but 16 min drive) using off duty personal convenience\nCould I make it if I will have avaible driving hours/shift/cycle? And return back after 10 hours?\nAnd second question: 15 min driving like off duty plus 9 hours and 45 minutes will they count with my 9 hours and 45 minutes? Or off duty driving will not calculate to my sleep hours?\nPlease assist ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-13 06:41:49 来自手机 | 显示全部楼层
118727 发表于 2020-02-12 21:48:08 If you go on PC and go to the truck stop it will ask you to communicate why. then go to the truck stop then go off duty for 10 hour's. I have done this myself and never had a issue.
","text":"pc anytime weather you have time or not. its pc. I'm self owner opp. I just unplug it.","replyToPid":325106}
发表于 2020-2-13 05:48:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you go on PC and go to the truck stop it will ask you to communicate why. then go to the truck stop then go off duty for 10 hour's. I have done this myself and never had a issue.","replyToPid":0}
发表于 2020-2-13 12:09:46 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I did it all the time at the last company I worked for.  Got unloaded, PC to a truckstop to wait for next load.  Drop off empty at Tyson plant, PC to a truckstop to wait.  Or PC to a zoo, park, store, then pc back to finish waiting.\n\nPC is off duty time, it counts as time for your 30min break and 10 hour break.  It will also count towards the 2hr break of an 8/2."}
发表于 2020-2-13 14:59:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"after dropping trailer you can go to truck stop on PC but u can not go to pick up a load/trailer from truck stop on PC. its that simple!","replyToPid":0}
发表于 2020-2-13 06:56:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"pc does not count for nothing. It’s just that personal conveyance. It is recognized as your personal time and DOES NOT apply towards your 70 hour clock.  I urge you not to abuse this for company drivers. Probably if you work for a huge outfit they may reprimand you. Best to check with your company policy. ","replyToPid":0}
发表于 2020-2-13 06:51:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"If I’m done for the day and mt, I will pc to truck stop if I know I’ll run out of hours. ","replyToPid":0}
 楼主| 发表于 2020-2-16 11:13:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks everybody to answer, I’m really appreciate it!","replyToPid":0}
GMT+8, 2026-4-17 23:25 , Processed in 0.141884 second(s), 24 queries .
