查看: 153|回复: 5
Quick question.
 楼主| 发表于 2020-2-13 04:19:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"If my engine block is cast out of iron or mined in 1998. But my pistons are from ore that was mined in 2014 does that still make my truck a pre ELD truck? thank you. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-13 04:49:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ummm. \n\nSure. Why not. ","replyToPid":0}
发表于 2020-2-13 06:00:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"nope. it goes by engine serial number. it's cast on side of block","replyToPid":0}
发表于 2020-2-13 06:06:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"DOT goes by the serial number on the block, so that would be the determining factor of this situation ","replyToPid":0}
发表于 2020-2-13 06:12:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it’s 1998 block your ELD except ","replyToPid":0}
发表于 2020-2-13 08:37:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I heard talk about fmcsa making rules about gliders but I never looked to see if there are any. All this information is easy to find on their website ","replyToPid":0}
GMT+8, 2026-2-15 16:30 , Processed in 0.070099 second(s), 23 queries .
