查看: 260|回复: 4
UBER freight.
 楼主| 发表于 2019-5-31 22:12:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey guy. just curios Does anybody worked or working with Uber frieght? I heard Uber freight takes out Brokers and contacts u direct with the shipper and u make more money? also your own schedule ? like regular uber cab? thanks. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-1 01:56:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ummm, Uber Freight are Brokers in a brokering firm....they do take up to 50% off the top of the rates they got into the business at the right time for them to make money before the trucking industry \"Makes a Change\" to have the theft from brokers stopped by federal levels of Government ","replyToPid":0}
发表于 2019-6-1 06:16:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"I run for Uber freight some times. they are a broker like every other broker, the only difference is the app has set prices. if you don't see anything you like, don't book it. the freight brokering business is just like the stock market. the good thing about Uber is that they will give you loads even if your MC is new. the trade-off is the pay rate is lower","replyToPid":0}
 楼主| 发表于 2019-6-1 06:22:53 来自手机 | 显示全部楼层
462372 发表于 2019-05-31 22:16:17 I run for Uber freight some times. they are a broker like every other broker, the only difference is the app has set prices. if you don't see anything you like, don't book it. the freight brokering business is just like the stock market. the good thing about Uber is that they will give you loads even if your MC is new. the trade-off is the pay rate is lower
","text":"Thanks man. Another question. In uber can i pickup Box truck , sprinter van loads? do they have these loads too? it would be easy to drive around in sprinter and pickup the loads i guess. ","replyToPid":49962}
发表于 2019-6-1 10:15:40 来自手机 | 显示全部楼层
692960 发表于 2019-05-31 22:22:53 Thanks man. Another question. In uber can i pickup Box truck , sprinter van loads? do they have these loads too? it would be easy to drive around in sprinter and pickup the loads i guess.
","text":"as far as I know, Uber only does van and reefer, and judging from the loads, they only do solo driver loads.","replyToPid":49970}
GMT+8, 2026-4-15 14:03 , Processed in 0.207247 second(s), 24 queries .
