查看: 175|回复: 18
photographer turn trucker
 楼主| 发表于 2020-2-12 17:06:35 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m just a photographer turn trucker here to make the best out of the transition I’m new so any tips any advice I’m open thanks ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-13 03:12:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"selfies aren't allowed here unless you want negative attention. transcindy can help you with any trany questions","replyToPid":0}
发表于 2020-2-12 17:53:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"What's wrong with your transmission??","replyToPid":0}
发表于 2020-2-13 00:00:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Jusse Smollet is looking forward to seeing you.","replyToPid":0}
发表于 2020-2-12 23:52:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"this is not a dating site","replyToPid":0}
 楼主| 发表于 2020-2-14 04:49:11 来自手机 | 显示全部楼层
910129 发表于 2020-02-12 19:12:06 selfies aren't allowed here unless you want negative attention. transcindy can help you with any trany questions
","text":"Got it thanks ","replyToPid":324496}
发表于 2020-2-13 23:59:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"What do you call a black photographer?\n\nA nígger.","replyToPid":0}
发表于 2020-2-13 02:41:50 来自手机 | 显示全部楼层
915744 发表于 2020-02-12 18:35:40 My tip is in my wife. Then my goat. Then back to my wife. But only after she fills herself up with sand. \n\n\nWe’re freaky like that.
","text":"Who puts sand in goat? wife?","replyToPid":324471}
发表于 2020-2-13 02:35:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"My tip is in my wife. Then my goat. Then back to my wife. But only after she fills herself up with sand. \n\n\nWe’re freaky like that. ","replyToPid":0}
发表于 2020-2-13 08:17:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"where are you transcindy ?","replyToPid":0}
 楼主| 发表于 2020-2-13 16:01:45 来自手机 | 显示全部楼层
917683 发表于 2020-02-12 09:53:59 What's wrong with your transmission??
","text":"I meant transition ","replyToPid":324294}
 楼主| 发表于 2020-2-13 16:02:17 来自手机 | 显示全部楼层
103619 发表于 2020-02-12 15:52:28 this is not a dating site
","text":"Thanks for the update ","replyToPid":324404}
GMT+8, 2026-2-4 09:26 , Processed in 0.140127 second(s), 24 queries .
