查看: 313|回复: 10
prime time
 楼主| 发表于 2020-2-12 06:51:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":930.0,\"name\":\"\",\"url\":\"\",\"width\":1057.0}]","canComment":true,"externalShare":false}
发表于 2020-2-12 09:17:40 来自手机 | 显示全部楼层
915352 发表于 2020-02-12 00:38:00 That bridge seems too low. That sign says al trucks turn right.
","text":"That truck would fit easy under it. He should’ve just backed straight up and then turned right. You can get out and see if there’s a vehicle behind you or just look for shadows or headlights if at night. This entire process should take less than 1 minute after passing the turn and stopping at bridge. There’s little to no training in the industry. That was an expensive mess to clean up (10’s of thousands probably). ","replyToPid":323828}
回复 支持 6 反对 0
发表于 2020-2-12 10:09:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"As slow as they move it's mind boggling they didn't see the sign","replyToPid":0}
发表于 2020-2-12 09:35:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"13'10\"?? there ain't no way that is 13'10\".  But still, there's two signs that say all trucks turn right.  So, one he was smart enough to realize that the bridge was too low but not smart enough to just back straight up! Good Job, Prime...","replyToPid":0}
发表于 2020-2-12 07:07:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"How? Why?","replyToPid":0}
发表于 2020-2-12 12:33:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why don’t they teach these drivers to back up? That’s most important part of trucking ","replyToPid":0}
发表于 2020-2-12 10:47:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"just looking for parking in California","replyToPid":0}
发表于 2020-2-12 08:39:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Truck route take right behind the the yellow sind","replyToPid":323825}
发表于 2020-2-12 08:34:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"So many questions, ","replyToPid":0}
发表于 2020-2-12 08:38:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"That bridge seems too low. That sign says al trucks turn right.","replyToPid":0}
GMT+8, 2026-2-14 02:25 , Processed in 0.114010 second(s), 24 queries .
