查看: 289|回复: 10
Sleeper
 楼主| 发表于 2020-2-10 11:35:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"Would anyone know where I could get a sleeper installed on 2017 ram mega cab 3500 that would be DOT certified? \n","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-10 11:38:55 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Is it even worth it?  Those things are like $20k.  Then you have to stretch the frame.  And still have to run logs.  Why not just buy a used freight shaker (if you get an older one, it would have been built by Damlier/Chrysler, so kinda the same thing)? \n\nNot knocking your plan, just curious."}
发表于 2020-2-10 13:33:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Contact me. I have a guy who makes sleepers and more stuff for ram 3500 and Ford F-350,450,550","replyToPid":0}
 楼主| 发表于 2020-2-10 11:42:17 来自手机 | 显示全部楼层
223292 发表于 2020-02-10 03:38:53 ARI in Shipshewana,  Indiana.  I had  90\"  bunk built for my 94 Pete.
","text":"Thanks","replyToPid":322216}
发表于 2020-2-10 11:38:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"ARI in Shipshewana,  Indiana.  I had  90\"  bunk built for my 94 Pete.","replyToPid":0}
 楼主| 发表于 2020-2-10 11:44:15 来自手机 | 显示全部楼层
859407 发表于 2020-02-10 03:38:55 Is it even worth it?  Those things are like $20k.  Then you have to stretch the frame.  And still have to run logs.  Why not just buy a used freight shaker (if you get an older one, it would have been built by Damlier/Chrysler, so kinda the same thing)? \n\nNot knocking your plan, just curious.
","text":"Just bought the truck. Company in Indiana does the ram extended cabs for 5g but not the mega cabs. ","replyToPid":322217}
发表于 2020-2-10 11:46:55 来自手机 | 显示全部楼层
{"replyToPid":322224,"replyTo":"
883993 发表于 2020-02-10 03:44:15 Just bought the truck. Company in Indiana does the ram extended cabs for 5g but not the mega cabs.
","text":"That isn’t a bad deal.  I was looking at a cascading last fall for $27k. \n\nHow much weight can you tow with that thing?  "}
发表于 2020-2-10 11:51:27 来自手机 | 显示全部楼层
","text":"Can you do me a favor and pm me when you get your numbers?  I would like to know how that turns out.","replyToPid":322224}
 楼主| 发表于 2020-2-10 11:51:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m towing travel trailers and 5th wheels. Can do 20,000 lbs with no problem. ","replyToPid":0}
 楼主| 发表于 2020-2-10 11:52:50 来自手机 | 显示全部楼层
859407 发表于 2020-02-10 03:51:27 Can you do me a favor and pm me when you get your numbers?  I would like to know how that turns out.
","text":"Will do \nCheers. ","replyToPid":322231}
GMT+8, 2026-4-16 10:05 , Processed in 0.091986 second(s), 24 queries .
