查看: 269|回复: 9
legal placards
 楼主| 发表于 2020-2-9 23:02:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"\nDoes anyone know if it's legal to put your own numbers own placards like the top one.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":3264.0,\"name\":\"\",\"url\":\"\",\"width\":2448.0}]","canComment":true,"externalShare":false}
发表于 2020-2-9 23:58:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Technically, it's legit because it is identifying the contents and danger therein with a UN number on a placard set on point. Personally, I would use an official placard printed with the UN number because what's in this photo looks sloppy and begging for attention from a DOT officer who's already having a bad day. Hope this helps.","replyToPid":0}
发表于 2020-2-11 08:37:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"I wouldn't run with that. If you can find a corrosive placard with numbers, you can cut numbers from other placards and assemble a placard with the proper size and spacing.","replyToPid":0}
发表于 2020-2-10 03:01:43 来自手机 | 显示全部楼层
877832 发表于 2020-02-09 15:58:58 Technically, it's legit because it is identifying the contents and danger therein with a UN number on a placard set on point. Personally, I would use an official placard printed with the UN number because what's in this photo looks sloppy and begging for attention from a DOT officer who's already having a bad day. Hope this helps.
","text":"Plus, they’re  under $5/each","replyToPid":321845}
发表于 2020-2-10 00:17:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only if it says on the bills & it's not correct on the trailer. Otherwise, your call. 🤔","replyToPid":0}
发表于 2020-2-21 19:10:31 来自手机 | 显示全部楼层
688983 发表于 2020-02-20 22:51:31 Numbers in the wrong spot , so that makes it illegal.
","text":"Wrong, but thanks for playing.","replyToPid":329127}
发表于 2020-2-21 19:14:57 来自手机 | 显示全部楼层
688983 发表于 2020-02-20 22:54:15 If it not in a tote , depending on the chemical you do not need the numbers . \nBasically what placard  on the containers should be on the trailer .
","text":"Class 8 Corrosive is a Table 2 Hazmat, meaning as long as there are at least 1,001 pounds of that particular product being shipped, corrosive placards with a UN number must be showing.","replyToPid":329130}
发表于 2020-2-21 19:29:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go back and learn the difference between table 1 and table 2. Table 1= ANY AMOUNT. TABLE 2= AT LEAST 1,001 LBS. AGGREGATE GROSS WEIGHT IN NON-BULK CONTAINERS OR 119 GALLONS IN BULK. As matter of fact, uranium hexaflouride is the only material that requires a subsidiary corrosive placard even when under the 1,001 pound minimum.","replyToPid":0}
发表于 2020-2-21 19:32:26 来自手机 | 显示全部楼层
688983 发表于 2020-02-21 11:20:57 Also the numbers are in the wrong spot .
","text":"Go back and learn the difference between table 1 and table 2. Table 1= ANY AMOUNT. TABLE 2= AT LEAST 1,001 LBS. AGGREGATE GROSS WEIGHT IN NON-BULK CONTAINERS OR 119 GALLONS IN BULK. As matter of fact, uranium hexaflouride is the only material that requires a subsidiary corrosive placard even when under the 1,001 pound minimum. Also, the UN is legal, although I wouldn't run with it like that.","replyToPid":330224}
发表于 2020-2-21 19:51:47 来自手机 | 显示全部楼层
it is in the middle area . not at the top
{"replyToPid":330231,"replyTo":"
688983 发表于 2020-02-21 11:41:05 it is in the middle area . not at the top
","text":"Yes, placards are printed with the UN number in the center. I never said they're not. Although this photo depicts a placard with the UN number at the top of the placard, it is still legal. I can see that the product contained in the trailer is a Class 8 Corrosive Sodium Hydroxide based on the info relayed on the placard."}
GMT+8, 2026-4-17 21:41 , Processed in 0.126189 second(s), 24 queries .
