查看: 148|回复: 3
Is the trucker path load board any good?
 楼主| 发表于 2020-2-9 15:56:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"Do you currently use it?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-9 21:26:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"It has some loads on it it’s ok ","replyToPid":0}
发表于 2020-2-9 16:52:55 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I have used it. It can be useful if your usual sources dry up. I have a couple regional brokers I am solid with from it. Just be careful. There are scammers that double and triple book and other nightmares. The board is good, but always research the broker."}
 楼主| 发表于 2020-2-10 01:54:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Okay, thank you guys, I was thinking about buying their load board.","replyToPid":0}
GMT+8, 2026-2-15 19:19 , Processed in 0.048481 second(s), 24 queries .
