查看: 95|回复: 7
Road pro 12v roaster
 楼主| 发表于 2020-2-8 08:19:24 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone else have problems with this roaster blowing your fuses? I’ve bought 2 of them now, thinking the first had a defect but same thing with the second one. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-8 09:59:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"It’s the product. A lot of Road Pro products aren’t rated properly to prevent this. Get yourself a high wattage inverter and a cheap roaster that uses a standard 110 plug. Don’t try cooking through the 12v cigarette lighter receptacle as it also can’t handle the amperes to support the wattage output. Only low wattage tech should be used with the cig lighter. "}
发表于 2020-2-8 10:23:53 来自手机 | 显示全部楼层
497499 发表于 2020-02-08 01:59:49 It’s the product. A lot of Road Pro products aren’t rated properly to prevent this. Get yourself a high wattage inverter and a cheap roaster that uses a standard 110 plug. Don’t try cooking through the 12v cigarette lighter receptacle as it also can’t handle the amperes to support the wattage output. Only low wattage tech should be used with the cig lighter.
","text":"Yep!  And if you doubt Scott, just pull your dash part and look at the 16g wire powering your 12v outlet.\n\nI wouldn’t run more than a few amps across that","replyToPid":321125}
发表于 2020-2-8 11:13:14 来自手机 | 显示全部楼层
900409 发表于 2020-02-08 03:01:10 I have one of the 12v lunch kit style cookers. \n\nWorks good for reheating. \n\nBut my raw cabbage rolls take at least 2hrs.
","text":"I have one too.  I cook Walmart mini pizzas in it.  30 mins and it is hot.  Too hot.  I also cook cans of soup on the dash. Using the defroster. Under a hoodie.\n\nClassy, I know. 🤷🏻‍♂️","replyToPid":321145}
发表于 2020-2-9 06:47:07 来自手机 | 显示全部楼层
","text":"Ohms Law","replyToPid":321125}
发表于 2020-2-8 11:01:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have one of the 12v lunch kit style cookers. \n\nWorks good for reheating. \n\nBut my raw cabbage rolls take at least 2hrs. ","replyToPid":0}
 楼主| 发表于 2020-2-9 05:28:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve got a lunchbox cooker too, it works fine, the roaster says it uses the same wattage but blows a 30 amp fuse every time ","replyToPid":0}
发表于 2020-2-9 05:29:46 来自手机 | 显示全部楼层
404912 发表于 2020-02-08 21:28:28 I’ve got a lunchbox cooker too, it works fine, the roaster says it uses the same wattage but blows a 30 amp fuse every time
","text":"put a 40 amp fuse in.","replyToPid":321514}
GMT+8, 2026-2-14 06:13 , Processed in 0.074621 second(s), 24 queries .
