查看: 180|回复: 9
SUSPENSION DUMP PROBLEM
 楼主| 发表于 2019-5-31 06:13:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does anyone drive the International truck LT 2019 or above ? How do you deal with it not having the air suspension dump switch? What if you wanna hook a trailer so low that you’d need to drain the airbags? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-31 17:47:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve owned many trucks without suspension dumps","replyToPid":0}
发表于 2019-5-31 06:42:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"😱 how is it possible for a truck to not have that?!?","replyToPid":0}
发表于 2019-5-31 07:38:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you sure you’re not just overlooking the switch? ","replyToPid":0}
发表于 2019-5-31 18:18:33 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"the last LT I was in had the dump switch and axle interlock etc covered up by the elog monitor"}
发表于 2019-5-31 19:18:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve driven quite a few internationals that didn’t have the airbag dump switch unfortunately if you are hooking to a low trailer you have to crank it up or have yard driver lift trailer so you can dolly the legs down more","replyToPid":0}
发表于 2019-5-31 20:59:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just ran into this problem a couple days ago. I have a new Freightliner doesn't have a dump switch either. After a quick Google search there's a valve that releases the air in the bags but you have to climb under the truck and pull the rod off of the pin. Then climb back under when you're ready and put the rod back on it's a pain at least that's what I can do maybe you have the same option if you feel like climbing underneath.","replyToPid":0}
 楼主| 发表于 2019-5-31 10:19:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s absurd I know. International seems to be a lazy a$$ truck maker ","replyToPid":0}
 楼主| 发表于 2019-5-31 22:26:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks guys ! I’m having some ideas from the comments","replyToPid":0}
GMT+8, 2026-4-18 04:07 , Processed in 0.109029 second(s), 24 queries .
