查看: 472|回复: 13
Cascadia Cruise control not working.
 楼主| 发表于 2019-5-31 05:36:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"hey guys. 2019 Cascadia. When i turn ON cruise control truck begins to Stop because truck system thinks that there is a car in front of him.   how i can reset Adaptive cruise control? or any other advise? ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":562.0,\"name\":\"\",\"url\":\"\",\"width\":750.0}]","canComment":true}
发表于 2019-5-31 12:34:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is the license plate blocking the sensor? The sensor should be in the middle just under the plate .crappy system it can pick up overpassed and overhead signs sometimes and then it puts the drive axel brakes on only and it can cause a start of a jack knife if the road has a slippery or wet spot when that happens . I just hate that system .","replyToPid":0}
发表于 2019-5-31 12:13:46 来自手机 | 显示全部楼层
692960 发表于 2019-05-30 21:46:15 it is clean. but where exactly the sensor located?
","text":"Sensor is the little black box on the front of the grill.  It might need adjusting.  Mine kept slamming on the brakes everytime I went under a bridge and it caught the shadow.  Turns out the box itself was slightly tilted.","replyToPid":49173}
发表于 2019-5-31 05:41:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Something stuck in ur grill blocking a sensor?","replyToPid":0}
发表于 2019-5-31 12:42:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"put your foot on the accelerator, it should override the adaptive cruise and let you roll full speed.","replyToPid":0}
发表于 2019-5-31 06:31:55 来自手机 | 显示全部楼层
654793 发表于 2019-05-30 21:41:12 Something stuck in ur grill blocking a sensor?
","text":"on a freightliner hit the on and off on cruise i bybass it","replyToPid":49170}
 楼主| 发表于 2019-5-31 05:46:15 来自手机 | 显示全部楼层
","text":"it is clean. but where exactly the sensor located? ","replyToPid":49170}
发表于 2019-5-31 06:07:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"my 2019 Volvo has that to","replyToPid":0}
发表于 2019-5-31 06:09:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"I honestly don’t know. Look in ur owners manual or online. Gotta b tucked in the grill or bumper somewhere I would assume. ","replyToPid":0}
发表于 2019-5-31 07:06:11 来自手机 | 显示全部楼层
","text":"yeah hit the on and off on the cruise control it should bybass the safety alert system","replyToPid":49170}
GMT+8, 2026-3-20 22:42 , Processed in 0.088787 second(s), 24 queries .
