查看: 244|回复: 28
Make Liberals Cry Again.
 楼主| 发表于 2020-2-6 00:12:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1392.0,\"name\":\"\",\"url\":\"\",\"width\":1439.0}]","canComment":true,"externalShare":false}
发表于 2020-2-6 00:49:01 来自手机 | 显示全部楼层
回复 支持 0 反对 8
发表于 2020-2-6 01:32:20 来自手机 | 显示全部楼层
回复 支持 1 反对 6
发表于 2020-2-6 01:08:21 来自手机 | 显示全部楼层
回复 支持 0 反对 6
发表于 2020-2-6 01:07:48 来自手机 | 显示全部楼层
回复 支持 0 反对 6
发表于 2020-2-6 05:16:44 来自手机 | 显示全部楼层
649124 发表于 2020-02-05 19:37:53 ...done on purpose...you nitwit!...to amplifie the almost religious fervor you hold to the most incompetent,illiterate, ill informed person to hold the Oval office...
","text":"...Tweek!...who’s the real doofus here?...you’ve been misspelling and...argh!..using the wrong punctuation all...waaah!...dàmn day!...MAYBE you should...whoa!...put down the crack pipe, ya jizz laden gimp!🤪😘🤘","replyToPid":319705}
发表于 2020-2-6 03:42:21 来自手机 | 显示全部楼层
回复 支持 0 反对 5
发表于 2020-2-6 03:37:53 来自手机 | 显示全部楼层
回复 支持 0 反对 5
发表于 2020-2-6 01:35:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just like last night. Trump is the man!","replyToPid":0}
回复 支持 4 反对 1
 楼主| 发表于 2020-2-6 00:58:53 来自手机 | 显示全部楼层
649124 发表于 2020-02-05 16:49:01 trumptards!trumptards!Uuueeehhh!🙄🤡
","text":"Case in point.","replyToPid":319645}
 楼主| 发表于 2020-2-6 04:52:04 来自手机 | 显示全部楼层
","text":"lmao....riiiiight.  How is he illiterate? exactly.....how?","replyToPid":319705}
 楼主| 发表于 2020-2-6 01:11:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks like someone's triggered! ☝️LMFAO.","replyToPid":0}
 楼主| 发表于 2020-2-6 02:00:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Diminutive thought process?? lmfao...on posting a meme?  You're the one that commented 3 different times.   As far a being a simpleton....again, I say,  LMFAO!!  Firstly,  you spelled annointed wrong, it's anointed.  Secondly that word makes absolutely no sense at all in that statement you made.  Do you even know the meaning of the word 'anoit' or 'anointed'??? \n\nanoint: to smear or rub with an oil, typically as part of a religious ceremony\n\nanointed:past tense.  The priests were anointed with oil.","replyToPid":0}
 楼主| 发表于 2020-2-6 02:03:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Soo... love the dames apparently had some ceremonial oil smeared on him after reading my meme.  My meme was so great that he felt a religious connection and had to be anointed.","replyToPid":0}
GMT+8, 2026-2-14 09:16 , Processed in 0.069889 second(s), 24 queries .
