查看: 74|回复: 2
CAT SCALE
 楼主| 发表于 2019-5-31 02:53:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"When you leave the shipper and weigh, do you set you tandems to the most restrictive state you’re traveling through? \nOr through the state where you pick up the load and then adjust as you go?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-31 04:20:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I set them to the most restrictive state I'm traveling through. just in case it's overweight then I can go back to the shipper and they could readjust the load or pull some Freight off.","replyToPid":0}
发表于 2019-5-31 05:12:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, When in doubt Scale it at the Closest CAT scale to your location even if it's not in the direction of your route, Always it's cheaper than a overweight ticket, If it is overweight and you can't slide your Tandems to make weight or it's simply over gross, Take it back to have them take weight off, and fill up your tanks before you scale. Hope it helps good luck.","replyToPid":0}
GMT+8, 2026-2-5 03:43 , Processed in 0.084452 second(s), 23 queries .
