查看: 169|回复: 0
Oil leak Cummins isx KW T660
 楼主| 发表于 2019-1-25 16:00:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello, I've got a minor oil leak in the back of the engine on passenger side, but not sure where is it coming from. Went to the shop, they replaced egr heater and told me that that it was it. 700 miles later fresh oil stain reappeared at the same spot. Maybe any of you ran into the same issue or might have an idea what may be the cause?\nThank you","pics":"[]","canComment":true}
GMT+8, 2026-3-21 09:31 , Processed in 0.065978 second(s), 23 queries .
