查看: 129|回复: 8
you're welcome!!!
 楼主| 发表于 2020-2-4 06:50:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"bacon that has nothing better to do with there life then mess with us ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":346.0,\"name\":\"\",\"url\":\"\",\"width\":550.0}]","canComment":true,"externalShare":false}
发表于 2020-2-5 06:46:38 来自手机 | 显示全部楼层
859407 发表于 2020-02-04 15:24:31 So, the fact that they can search, without cause, your phone and your cab, (home) makes your point valid.  \nBut I have seen enough trucks on the road with tires I would not run on a wheel barrow to think that scales aren’t that bad of a deal.
","text":"Yes, unfortunately I agree. Many truckers have made checking us constantly a necessity. I keep my truck legal all the time. Every dot officer I’ve ever interacted with has been professional and courteous so I’m not necessarily against it because we need safer roads. I’d say stop all the 4 wheelers just to be consistent ","replyToPid":318861}
发表于 2020-2-4 23:24:31 来自手机 | 显示全部楼层
255377 发表于 2020-02-04 07:07:41 Tyranny at it’s finest. What 4th amendment?
","text":"So, the fact that they can search, without cause, your phone and your cab, (home) makes your point valid.  \nBut I have seen enough trucks on the road with tires I would not run on a wheel barrow to think that scales aren’t that bad of a deal. ","replyToPid":318362}
发表于 2020-2-4 09:29:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"*their life* again, you're (you are) welcome.","replyToPid":0}
发表于 2020-2-4 08:03:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"you're (you are) You're welcome.","replyToPid":0}
发表于 2020-2-5 06:50:28 来自手机 | 显示全部楼层
","text":"I kinda agree.  I sometimes have had a truck with air that cuts off every minute or two park next to me for the night.   I pray dot gets them.","replyToPid":318861}
 楼主| 发表于 2020-2-4 08:09:12 来自手机 | 显示全部楼层
223292 发表于 2020-02-04 00:03:50 you're (you are) You're welcome.
","text":"thanks","replyToPid":318303}
发表于 2020-2-4 15:07:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tyranny at it’s finest. What 4th amendment?","replyToPid":0}
发表于 2020-2-5 00:21:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"They got me last week on 81 North Troutville Virginia. Full inspection had an leak on passenger steer axle brake booster ","replyToPid":0}
GMT+8, 2026-2-15 23:25 , Processed in 0.071134 second(s), 24 queries .
