查看: 229|回复: 7
Engine overhauls
 楼主| 发表于 2020-2-2 10:39:38 来自手机 | 显示全部楼层 |阅读模式
{"text":"For those of you who have way more experience being an owner operator than I do, I have some questions. \n\n1. What is a good company to finance an out of frame engine overhaul?\n\n2. What is a good company to perform the overhaul?\n\n3. How long does it typically take?\n\n4. How much should I expect to pay for a good, timely overhaul?\n\nThanks in advance.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-3 05:46:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take to a certified shop so you get warranty do it closed to home it can take week to 10 days go to your local bank if you can ","replyToPid":0}
发表于 2020-3-9 10:24:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"$30-$40k if done with quality parts in a quality shop","replyToPid":0}
发表于 2020-2-7 05:21:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"should take about a week. 15k - 20k depending on engine and if you replace any other parts ie, turbo, air compressor, injectors, water pump, etc. Go to your bank and get a loan if you can. if your in a pinch. get an inframe and it will be much less.","replyToPid":0}
发表于 2020-2-3 02:35:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did my C15 overhaul at a caterpillar machinery shop ( heavy / work equipment ) 2 years ago so far no problems just regular fluids change truck hasn’t being to the shop for engine problems not once. I think they have more knowledge than a regular mechanic at a dealer since they don’t overhaul engines in a daily basic.  26K worth it. ","replyToPid":0}
发表于 2020-2-2 12:04:08 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"$25k \n A week or so\nDepends on where you are, but if in northern Colorado/southeast Whyoming, message me\nYou must really like that tractor.."}
发表于 2020-2-2 12:01:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pittsburgh power","replyToPid":0}
发表于 2020-3-9 10:12:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"$5 - $10 total - depending on engine. Two days. If you need to finance it, I’d suggest not doing it unless you can sell the truck for a profit or break even on it once it’s done. Something has gone very bad for you somewhere.","replyToPid":0}
GMT+8, 2026-4-18 03:22 , Processed in 0.084833 second(s), 24 queries .
