查看: 439|回复: 24
question
 楼主| 发表于 2020-2-1 06:14:38 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a 30ft hotshot trailer, how much hangover are you allowed to have? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-1 06:41:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"lazyboy has it right.  I'm hotshot also. \nthey talk 💩 to me, but highly unlikely they will to you being that you're female","replyToPid":0}
发表于 2020-2-1 07:30:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"the length of the hangover you have usually depends on how much you've had to drink","replyToPid":0}
发表于 2020-2-1 06:31:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Anything over 3 ft u need a red flag and ive never hung over more than 5....\n Im a hot shot as well and hope that helps ... Good Luck","replyToPid":0}
发表于 2020-2-2 11:35:23 来自手机 | 显示全部楼层
910129 发表于 2020-01-31 22:41:47 lazyboy has it right.  I'm hotshot also. \nthey talk 💩 to me, but highly unlikely they will to you being that you're female
","text":"your the real hero if u ask me mr paperlog certified","replyToPid":317114}
发表于 2020-2-1 12:41:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"hotshot drivers are just training wheels because you didnt get the full package!! but welcome","replyToPid":0}
发表于 2020-2-1 22:45:34 来自手机 | 显示全部楼层
859407 发表于 2020-02-01 14:43:22 How much can you overhang with flags?  The trusses are 30’
","text":"honestly don't know.  I've been 7' over","replyToPid":317220}
发表于 2020-2-1 22:20:34 来自手机 | 显示全部楼层
","text":"How much weight can you haul?  And how long is your trailer?\n\n(I am getting ready to move a building and need some hard numbers, please)","replyToPid":317114}
发表于 2020-2-1 16:48:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never no more then 3ft hang over and no more than 2ft on the front I pull flat bed","replyToPid":0}
 楼主| 发表于 2020-2-1 06:35:58 来自手机 | 显示全部楼层
197817 发表于 2020-01-31 22:33:57 i'd say up to 3-4 ft? i've hauled pipes with 4ft over with no problem. put a few flags on it as well
","text":"Thank you 😊","replyToPid":317110}
发表于 2020-2-1 06:33:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"i'd say up to 3-4 ft? i've hauled pipes with 4ft over with no problem. put a few flags on it as well","replyToPid":0}
 楼主| 发表于 2020-2-1 06:35:12 来自手机 | 显示全部楼层
404058 发表于 2020-01-31 22:31:19 Anything over 3 ft u need a red flag and ive never hung over more than 5....\n Im a hot shot as well and hope that helps ... Good Luck
","text":"Yes it does, thank you so very much","replyToPid":317108}
发表于 2020-2-1 06:50:19 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"..."}
发表于 2020-2-1 07:46:05 来自手机 | 显示全部楼层
627193 发表于 2020-01-31 23:30:36 the length of the hangover you have usually depends on how much you've had to drink
","text":"good one  🍻🥃😵🤢","replyToPid":317126}
发表于 2020-2-1 12:07:05 来自手机 | 显示全部楼层
627193 发表于 2020-01-31 23:30:35 the length of the hangover you have usually depends on how much you've had to drink
","text":"lmao u never disappoint..  🤣","replyToPid":317125}
GMT+8, 2026-2-4 18:37 , Processed in 0.081822 second(s), 24 queries .
