查看: 219|回复: 9
Highway Etiquette
 楼主| 发表于 2020-2-1 04:44:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"Thinking of bringing extra tents along for the drive so that I can chuck them out the window at the four wheelers that like to camp out at the last 10-12 feet of my trailer, and charge $50 for the stay for my sight side and $75 for my blindside.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-1 06:22:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I took a picture of a trailer, (unfortunately it was too out of focus), on the left side it said \"El Paso\" and on the other side it said \"El Smasho\"🤣","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-2-1 07:05:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Put spot lights on the back of your trailer under the frame. If someone’s to close, flip those puppies on and watch them slam their brakes and easy up off your back side. I’m working on the business plan for it. 👍","replyToPid":0}
发表于 2020-2-1 05:30:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hit my brakes and slow down too to get them to go around. idiots","replyToPid":0}
 楼主| 发表于 2020-2-1 06:21:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’d sometimes speed up or slow down and watch them match my speed to consistently stay in the same geographical location. It doesn’t make sense.?","replyToPid":0}
发表于 2020-2-1 06:02:31 来自手机 | 显示全部楼层
{"replyToPid":317088,"replyTo":"
780067 发表于 2020-01-31 21:49:55 They won't see them any more than they see the great big \"Caution Wide Turns\" and still try to turn inside of us...but best wishes to you! Maybe you can finally make a way to help them see the realities!
","text":"I’ve had them pass me and turn right at a stop 🛑 sign as I have my right blinker on. I actually see all around me and am not concerned with any of this as I fully expect them to do the wrong thing all the time and I act accordingly. The only thing that bothers me about how people drive around me is when they get directly in front of me. I can’t do much about that. I had it happen once where a 4 wheeler pulled out in front of me from a dead stop. The only thing that saved them was I grabbed the shoulder. The hammer lane was backed up for left hand exit. It’s happened a few times but I have cat like reflexes and an angel 👼 watching over me "}
发表于 2020-2-1 12:44:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"only good thing about American pennies, they finally have a use ....","replyToPid":0}
发表于 2020-2-1 05:34:34 来自手机 | 显示全部楼层
805928 发表于 2020-01-31 21:30:48 I hit my brakes and slow down too to get them to go around. idiots
","text":"Same here. I’ve been working on a graphic to put on trailer doors showing “Truckers’ Blind Spots,” and “Danger Zones.” ","replyToPid":317078}
发表于 2020-2-1 05:49:55 来自手机 | 显示全部楼层
497499 发表于 2020-01-31 21:34:34 Same here. I’ve been working on a graphic to put on trailer doors showing “Truckers’ Blind Spots,” and “Danger Zones.”
","text":"They won't see them any more than they see the great big \"Caution Wide Turns\" and still try to turn inside of us...but best wishes to you! Maybe you can finally make a way to help them see the realities!","replyToPid":317081}
 楼主| 发表于 2020-2-1 07:25:12 来自手机 | 显示全部楼层
518050 发表于 2020-01-31 23:05:01 Put spot lights on the back of your trailer under the frame. If someone’s to close, flip those puppies on and watch them slam their brakes and easy up off your back side. I’m working on the business plan for it. 👍
","text":"Lol","replyToPid":317121}
GMT+8, 2026-2-16 00:44 , Processed in 0.053798 second(s), 24 queries .
