查看: 96|回复: 7
Hi, I shut off and on buttery once, and my bunk heater wont stop, working as a fan, even while driving still wont stop
 楼主| 发表于 2020-1-30 13:48:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"Freightliner cascadia 2015, bunk heater working as a fan, wont stop","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-30 13:53:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Inferior parts and engineering leads to problems such as this from time to time.","replyToPid":0}
 楼主| 发表于 2020-1-30 13:59:54 来自手机 | 显示全部楼层
255377 发表于 2020-01-30 05:53:33 Inferior parts and engineering leads to problems such as this from time to time.
","text":"So i have to pull to the shop🤔🤔, thank you! ","replyToPid":316179}
发表于 2020-1-30 14:04:16 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If it isn’t not turning off then it’s from the switch or you have another problem. Cheapest thing is a battery cut off switch if you have a main cable to tap into. Then you can make sure nothing ever drains the battery if you’re turning the truck off for a long time or overnight "}
发表于 2020-1-30 15:27:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"sounds electrical like a bad relay keeping the circuit closed","replyToPid":0}
发表于 2020-1-30 20:24:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"im having issues with my 2016 freightlinner rite now with eletrical causing my 12v out lits to surge and electronic to shut down","replyToPid":0}
发表于 2020-1-30 22:54:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's a multiplexing issue with bunk hvac ecu. Signal loss to shut ecu down. disconnect battery cables for several minutes until all shuts down. Should shut off after that. Or find bunk hvac ecu fuse.","replyToPid":0}
发表于 2020-1-31 00:02:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"cycle the power. shut on and off repeatedly around ten times this should reset the power module on the unit","replyToPid":0}
GMT+8, 2026-2-4 08:01 , Processed in 0.123246 second(s), 24 queries .
