查看: 112|回复: 3
Built in CB antennas
 楼主| 发表于 2020-1-30 06:15:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm looking for some feedback on how to access the built in antenna wires on the 2018 Freightliner Cascadia. I saw one useless video on YouTube. Would appreciate some serious info. Thanks","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-30 06:29:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"if they are designed the same as the 2015. there is a tray above your head. you have to pull hard on it to pop it loose. it has a tab on either side. they won't break. that should be where you put the cb. I really don't recommend using those cables. they're not very good. get a bracket from the truck stop. it attaches to the mirror. get a good antenna and cable.","replyToPid":0}
发表于 2020-1-30 06:29:47 来自手机 | 显示全部楼层
发表于 2020-1-30 06:30:30 来自手机 | 显示全部楼层
GMT+8, 2026-4-18 18:41 , Processed in 0.077245 second(s), 23 queries .
