查看: 593|回复: 32
What do you do???
 楼主| 发表于 2020-1-29 08:10:38 来自手机 | 显示全部楼层 |阅读模式
{"text":"When they park this close to you, you can’t get in or out your driver door😠😡😡😡🤬🤬🤬","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":992.0,\"name\":\"\",\"url\":\"\",\"width\":744.0},{\"description\":\"\",\"height\":564.0,\"name\":\"\",\"url\":\"\",\"width\":750.0},{\"description\":\"\",\"height\":992.0,\"name\":\"\",\"url\":\"\",\"width\":744.0}]","canComment":true,"externalShare":false}
发表于 2020-1-29 09:12:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dump a jug of def in his fuel tank. \n\nSwitch his glad hands. \n\nBreak his trailer seal. \n\nStab a rad hose","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-1-29 08:41:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"pi.ss on his tires","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-1-29 08:50:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"grease their door step","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-1-29 08:56:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Kindly ask him to move up and if he doesn’t then it’s fair game. Anything can happen at a truck stop","replyToPid":0}
发表于 2020-1-29 10:30:59 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"It was me.  I cant back up so I pulled in. I need to wait for you to leave so I can get out without hitting your truck."}
发表于 2020-1-29 11:39:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"pour your p:ss jug in his def tank","replyToPid":0}
发表于 2020-1-29 11:20:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"take a dump in plastic bag, throw it on the windshield and make sure it leaks into the vent intake below windshield...","replyToPid":0}
发表于 2020-1-29 14:26:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"A. you obviously did get out and B. be glad they didn't take your mirror off.","replyToPid":0}
发表于 2020-1-29 09:53:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Odds are his trailer brakes aren’t set. \n\nCrawl under and tighten his slack adjusters","replyToPid":0}
发表于 2020-1-29 11:02:50 来自手机 | 显示全部楼层
900409 发表于 2020-01-29 01:12:58 Dump a jug of def in his fuel tank. \n\nSwitch his glad hands. \n\nBreak his trailer seal. \n\nStab a rad hose
","text":"you can't be canadian 😐","replyToPid":315189}
发表于 2020-1-29 09:00:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can always wind your window down and crawl out","replyToPid":0}
发表于 2020-1-29 09:13:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Other option is use the passenger side door, but only after pissin' on the steps.  Unless you can get high enough for the door handle ","replyToPid":0}
发表于 2020-1-29 09:26:10 来自手机 | 显示全部楼层
674254 发表于 2020-01-29 01:13:55 Other option is use the passenger side door, but only after pissin' on the steps.  Unless you can get high enough for the door handle
","text":"to old and not enough pressure LMAO","replyToPid":315190}
发表于 2020-1-29 09:29:54 来自手机 | 显示全部楼层
848274 发表于 2020-01-29 01:26:10 to old and not enough pressure LMAO
","text":"Stand on the steps LMFAO ","replyToPid":315195}
发表于 2020-1-29 09:31:17 来自手机 | 显示全部楼层
674254 发表于 2020-01-29 01:29:54 Stand on the steps LMFAO
","text":"sounds dangerous.  better use a jug and call it a day","replyToPid":315199}
GMT+8, 2026-2-15 08:58 , Processed in 0.103180 second(s), 24 queries .
