查看: 169|回复: 5
Help?
 楼主| 发表于 2020-1-29 01:24:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"I drive a  18’ freightliner cascadia. For some reason when it goes into battery mode it shuts all the power off and cranks up. Is there anyway I can make it to where it doesn’t cut the power off when going into power mode? I don’t always need interior comfort on but I try to cut it on before battery mode comes on so it doesn’t shut all my power off. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-1 00:17:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"same thing happened when I had on '18.. súcked cuz my laptop needs to be plugged in to stay on and this would shût it off everytime it went into battery mode.","replyToPid":0}
发表于 2020-1-29 11:30:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make sure you have the gel type batteries and not the acid type. Some repair shops swap them out and keep the gel batteries","replyToPid":0}
发表于 2020-1-29 01:44:22 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Is your truck equipped with park smart climate control? If it is, turn off interior comfort mode. I would also suggest you check your batteries for dead cells as well as your alternator to make sure it has a high enough amperage rating for any AC powered devices you have plugged in."}
发表于 2020-1-29 01:34:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds like auto idle. \n\nWhen oil temp drops it will fire up. \n\nMaybe your batteries can’t keep up?","replyToPid":0}
 楼主| 发表于 2020-2-4 04:19:48 来自手机 | 显示全部楼层
808178 发表于 2020-01-31 16:17:16 same thing happened when I had on '18.. súcked cuz my laptop needs to be plugged in to stay on and this would shût it off everytime it went into battery mode.
","text":"It’s quite annoying. I play console games from time to time and it’d go into battery mode while I’m in the middle of a match or game ","replyToPid":316930}
GMT+8, 2026-2-16 00:44 , Processed in 0.058100 second(s), 24 queries .
