查看: 302|回复: 13
mx13
 楼主| 发表于 2020-1-28 23:40:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"anybody ever had an overhaul done on a paccar mx13? what was the cost? I'm thinking probably 25k???","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-1 01:16:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"i did engine swap, got the engine for 14k with 140k miles on it. total was suppose to be 18k but i paid 22k since they had to do some more work on it ( as always ) rebuilding would have cost me between 14k and 18k but now i have almost new motor with all the original parts as turbo water pump egr comp etc...","replyToPid":0}
发表于 2020-1-29 01:36:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"look at LKQ , they have sometimes good options available.","replyToPid":0}
发表于 2020-1-29 00:23:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sometimes it’s not worth rebuilding an engine when you can buy a good used tractor for 50ish. Just a thought","replyToPid":0}
发表于 2020-1-29 00:31:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's been my experience.  I've had several trucks rebuilt over the years. with all the sensors and stuff on that engine. your looking at 50k.  they will tell you engine cost 25k. but will want turbo and various other components replaced or they won't do job.  plus no warranty","replyToPid":0}
发表于 2020-1-28 23:50:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can buy a remanufactured for $16-20k.  $25k  probably close.","replyToPid":0}
发表于 2020-1-29 00:29:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Overhaul? Driver run rods thru block and then just go to a dealership or mechanic shop. Tell them you’ve got 15 k and watch. I bet there going to pull out nice motor from somewhere, or truck lol","replyToPid":0}
发表于 2020-1-29 00:33:41 来自手机 | 显示全部楼层
484866 发表于 2020-01-28 16:31:28 it's been my experience.  I've had several trucks rebuilt over the years. with all the sensors and stuff on that engine. your looking at 50k.  they will tell you engine cost 25k. but will want turbo and various other components replaced or they won't do job.  plus no warranty
","text":"Wrong shop then.","replyToPid":314876}
 楼主| 发表于 2020-1-29 01:06:55 来自手机 | 显示全部楼层
901782 发表于 2020-01-28 15:50:09 You can buy a remanufactured for $16-20k.  $25k  probably close.
","text":"that definitely may be an option. I found online where I can get all the parts I want. and some I dont like injectors and water pump for 10k. that includes a new head. have fixed geometry turbo so they wont touch anything on exhaust side of head.","replyToPid":314850}
 楼主| 发表于 2020-1-29 01:08:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a extra vgt with only 5k miles put on it. paid 7k will sell for half price obo. come with Actuator","replyToPid":0}
发表于 2020-1-29 01:12:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"it was Detroit dealer 1st time. 2nd time it was Cummins shop. not a small shop","replyToPid":314877}
发表于 2020-1-29 01:25:04 来自手机 | 显示全部楼层
484866 发表于 2020-01-28 17:12:15 it was Detroit dealer 1st time. 2nd time it was Cummins shop. not a small shop
","text":"Yeah that's why the dealer always does the extra so you cant come back try to blame them.  I like the little shops for the things I cant do on my own.","replyToPid":314891}
GMT+8, 2026-4-18 03:22 , Processed in 0.433342 second(s), 24 queries .
