查看: 297|回复: 18
What would you guys like to say about this kinda parking?
 楼主| 发表于 2020-1-27 14:30:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1134.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true,"externalShare":false}
发表于 2020-1-27 14:52:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Who Cares Driver? are you parked? do you need that driver to move?  If so then knock on that door... \n\nSimpleton... \n\nCheers!","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-1-27 15:15:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think we should post pics. Public shaming actually works it turns out ","replyToPid":0}
发表于 2020-1-28 00:08:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"It ain't your problem.. shut the curtains, rub one off and go to bed","replyToPid":0}
发表于 2020-1-27 20:38:27 来自手机 | 显示全部楼层
626560 发表于 2020-01-27 06:52:50 Who Cares Driver? are you parked? do you need that driver to move?  If so then knock on that door... \n\nSimpleton... \n\nCheers!
","text":"why in the f\"ck where you peaking over at the urinals to take a look at everyone's junk? creepy. save that activity for you and your trans friends. fat azz","replyToPid":313768}
发表于 2020-1-27 15:09:07 来自手机 | 显示全部楼层
","text":"well said","replyToPid":313768}
发表于 2020-1-27 19:48:27 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Looks like enough space for you to fit next to him.  Bonus points if you are in the lines with the tail of your trailer just an inch or two away from him."}
发表于 2020-1-28 09:14:06 来自手机 | 显示全部楼层
626560 发表于 2020-01-27 21:40:52 So other then being a typical A**hole truck driver that enjoys shaming others, It also sounds like you have some security issues also. \n\nWhat happened to you as a child? Daddy come home amd beat you and you Mom? Was your homophobia instilled as a child or did you have to work on that later in life?  \n\nI think you need some psychiatric help to work on your issues. \n\nCheers!
","text":"nope. just dont like you. sounds like nobody else does either. so go choke on a panini or a big fat man sausage. make no diff to me diva","replyToPid":314237}
发表于 2020-1-28 01:34:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"transcindy says you gave him her the the respect he she deserves over the weekend. says heshe is but t hurt over that pounding you gave him her. sounds like you both enjoyed yourselves.","replyToPid":0}
发表于 2020-1-27 18:39:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤦🏽‍♂️","replyToPid":0}
发表于 2020-1-27 18:37:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's fckd  up","replyToPid":0}
发表于 2020-1-27 22:38:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"looks like that driver is saving a spot for his buddy.. I do that when I'm waiting for my old man to arrive.  like within the hr or two..","replyToPid":0}
GMT+8, 2026-2-14 16:12 , Processed in 0.095621 second(s), 24 queries .
