查看: 376|回复: 38
ANNOYING APU. inconsiderate driver don't care where they park about time someone said something every one is thinking
 楼主| 发表于 2020-1-27 03:44:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"why do they put them annoying apu's on the right side of there truck then park next to me so I can hear it. I carry potatoes with me just 4 them.  what do y'all use to quiet them.  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-27 04:49:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't give a SH IT who parks next to me. Thay have as much right to a parking spot as I do...","replyToPid":0}
回复 支持 15 反对 1
发表于 2020-1-27 04:15:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"so running ur loud engine is ok, but not an apu? reefer units must be bad too for you, huh? maybe you need to get off the road and back to something that's not too loud, like being a librarian. 🤦‍♂️😭😭","replyToPid":0}
回复 支持 12 反对 2
发表于 2020-1-27 04:48:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"what do you do with the potatoes?  you're a nasty person if you are damaging others equipment.  apu's are part of truck driving.  I use a fan for white noise and a little zquil helps also.","replyToPid":0}
回复 支持 11 反对 1
发表于 2020-1-27 05:14:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t park at truck stops think outside the coconut ya meat head","replyToPid":0}
回复 支持 7 反对 0
 楼主| 发表于 2020-1-27 04:51:51 来自手机 | 显示全部楼层
816144 发表于 2020-01-26 20:26:29 If you’re having a hard time sleeping in truckstops then maybe you should find a job that does not require you to sleep in truck stops, you fúcking imbecile. Go flip burgers or something, then when you clock out you can go home with your binky and baba and sleep soundly.
","text":"I just fire up my reefer","replyToPid":313421}
回复 支持 5 反对 2
 楼主| 发表于 2020-1-27 04:58:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"oh running an engine is great helps me sleep","replyToPid":0}
回复 支持 4 反对 2
 楼主| 发表于 2020-1-27 04:56:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"u probably one them puds complaining about reerrers","replyToPid":0}
回复 支持 4 反对 2
 楼主| 发表于 2020-1-27 04:50:29 来自手机 | 显示全部楼层
805928 发表于 2020-01-26 20:15:34 so running ur loud engine is ok, but not an apu? reefer units must be bad too for you, huh? maybe you need to get off the road and back to something that's not too loud, like being a librarian. 🤦‍♂️😭😭
","text":"I pull a reefer. if it's not running when they park next to me it will be shortly","replyToPid":313416}
回复 支持 5 反对 1
发表于 2020-1-27 06:28:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"apu complaint lol they are so quiet compared to literally everything else out here","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-1-27 06:06:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t have a problem with anything at the truck considering APUs but 1 thing.  \nI parked next to a guy that was obliviously sitting when I parked. But I go to lay down and I wake up 1 hour later to a horrible headache. Can’t see straight, eye lids are fluttering, neck is cramped up all the way from shoulder blade to the top of my skull. Turns out the guy next to me with his APU exhaust facing away from his truck on the passenger side is blowing all his fumes at my sleeper. This I don’t usually mind but his exhaust wash blowing out bad white smoke. Like he blew a head gasket. I never wanted to go kick someone’s door so badly in my life. Guy had to have money judging from how chromed out his truck was but yeah I left shortly after that. Was not gonna stick around to get killed by another drivers ignorance to check his dam equipment. ","replyToPid":0}
 楼主| 发表于 2020-1-27 05:17:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'll park where I want. if my reefer not running it can be.","replyToPid":0}
GMT+8, 2026-2-14 16:12 , Processed in 0.088943 second(s), 24 queries .
