查看: 111|回复: 15
stubs jokes, to much time alone.
 楼主| 发表于 2020-1-26 01:12:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[{\"url\":\"http://d2w8udw005hdju.cloudfront.net/video/251414/android_60662_1579972255057.mp4\"}]","link":"{}","pics":"[{\"description\":\"\",\"height\":607.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true,"externalShare":false}
发表于 2020-1-26 01:24:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"LMAO you're NUTZ","replyToPid":0}
发表于 2020-1-26 01:33:39 来自手机 | 显示全部楼层
60662 发表于 2020-01-25 17:29:39 I have a  couple I used to test the water when hitting on a chick in the bar. if they would laugh then I would offer a get to know you better drink
","text":"😉🍹","replyToPid":312469}
发表于 2020-1-26 01:33:56 来自手机 | 显示全部楼层
60662 发表于 2020-01-25 17:31:32 got to be a little insane to stay sane
","text":"🙃🤪🤯","replyToPid":312473}
发表于 2020-1-26 01:48:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤣","replyToPid":0}
发表于 2020-1-26 01:29:04 来自手机 | 显示全部楼层
60662 发表于 2020-01-25 17:26:07 thank you  I believe you are correct sir
","text":"I'm usually correct about that subject.  takes 1 to know 1","replyToPid":312460}
 楼主| 发表于 2020-1-26 01:29:39 来自手机 | 显示全部楼层
","text":"I have a  couple I used to test the water when hitting on a chick in the bar. if they would laugh then I would offer a get to know you better drink","replyToPid":312460}
 楼主| 发表于 2020-1-26 01:31:32 来自手机 | 显示全部楼层
848274 发表于 2020-01-25 17:29:04 I'm usually correct about that subject.  takes 1 to know 1
","text":"got to be a little insane to stay sane","replyToPid":312466}
发表于 2020-1-26 01:33:23 来自手机 | 显示全部楼层
","text":"used to date a pumper with that line🤣🤣🤣","replyToPid":312469}
 楼主| 发表于 2020-1-26 01:26:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you  I believe you are correct sir","replyToPid":312458}
 楼主| 发表于 2020-1-26 02:54:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Glad you like it Pop's. a laugh a day keeps the doctor away","replyToPid":312515}
GMT+8, 2026-2-14 19:18 , Processed in 0.060883 second(s), 24 queries .
