查看: 579|回复: 19
Question for Owner Operators Why not run a day cab???
 楼主| 发表于 2020-1-26 00:51:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"Why don’t otr O/O buy day cab trucks??\nPros\nBetter fuel economy\nHaul heavier,more load options\nLower initial costs/truck payments \nOption for more fuel in tanks/bigger tanks\nSave money initial purchase plus fuel mpg \nCatch an Uber for 10 hr/34 reset to hotel write off on taxes as business expense\nEasier to get into tight docks or tight city\nCan run otr when rates are good or run day cab local when rates drop\n\nCons\nPerhaps a little rougher ride but I highly doubt that nowadays\nNo bunk/but hell wouldn’t we all rather stay in hotel??\n\nOnly reason I see an otr O/O needing a sleeper is if they haul sensitive material that requires them to stay with load entire trip if that is the case though you better be adding that to the price you haul it for.\n\nCan any O/O tell me why a sleeper makes more sense than a day cab??\n\nLike I said the hotel expense can be written off on taxes not to mention the initial 10-30k you save on initial purchase and better fuel economy \n\n","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-26 01:24:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wow you’re really on to something here 😆 275 nights away from home in a hotel to the tune of $25k annually minimum. Not to mention the Uber rides to/from. How about when I-80 is closed for 34+ hours in Wyoming like it was around New Years this year? Uber gonna come pick me up on Elk Mountain and take me to a hotel room?","replyToPid":0}
回复 支持 11 反对 0
发表于 2020-1-26 01:22:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"You're not saving with a hotel. Maybe the back end on taxes but that really doesn't help since it's at the end of the year. Also depending where you haul you might not be close to a hotel and a lot of areas don't have Uber or Lyft. While I see how you would think a day cab would be financially beneficial, the quality of life aspect makes a day can impractical.","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-1-26 01:18:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would say sure, but you’d have to keep a fold up bike or e-scooter on a rack with your 5th wheel back because rideshare and cabs aren’t available everywhere. ","replyToPid":0}
发表于 2020-4-23 06:22:30 来自手机 | 显示全部楼层
639250 发表于 2020-04-22 21:23:39 Makes no sense to me why owner operators would take loads more than 700 miles from where they are based being that eld that is about max you can get in a day...as an owner op you should be having way more home time than company driver otherwise your kinda failing goal is make more work less enjoy life, you can’t do that driving cross country every week chasing rates and loads away from home months at a time if you can’t get rates out of your area to cover costs and make decent profits then no point being owner op better off buying truck and hiring a driver to run cross country chasing rates for you while you focus on more profitable investments in your area
","text":"then do it and get back to us how it is working?","replyToPid":361905}
发表于 2020-3-20 09:51:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"LOL @ ‘’Catch an Uber for 10 hr/34 reset to hotel write off on taxes as business expense’’\n\nbrah you do that every day out here you will be broke, stay broke, and have about $10,000 in credit card debt in about four months then you will drop out and try to sell your fancy day-cab.  All because you want to look out the back window to back up.","replyToPid":0}
发表于 2020-3-21 17:26:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"No one in their right mind buys a day cab to run OTR","replyToPid":0}
发表于 2020-3-9 10:22:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Day cabs are for b itches and wannabes where I come from","replyToPid":0}
发表于 2020-1-26 01:37:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"some day cab operators will choose that fine suite and wonder why they never get a raise...now tell me how does help anyone?","replyToPid":0}
 楼主| 发表于 2020-1-29 15:24:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good points but that is where trip planning comes into play make sure to grab trips where there is easy access to hotels/Uber or just run short hop trips back and fourth ","replyToPid":0}
发表于 2020-3-9 11:54:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"because we would have to pay for hotels every night. you sum bïtch","replyToPid":0}
发表于 2020-1-26 07:23:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"con: motels are expensive","replyToPid":0}
发表于 2020-1-26 08:52:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"What happens when you’re stuck in the middle of nowhere sleeping on an on ramp🤷‍♂️","replyToPid":0}
发表于 2020-3-9 10:19:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s just simpler not to do it, and more people do it than I think you realize. There are large fleets that do it, and I’m not just talking about car haulers. You’ll probably see more if it as parking problems persist. That’s the best reason to do it. But it hasn’t been done as much in the past because real drivers sleep and go back to work. They get it done and get home and take that fat check to the bank. This “set up” in a sleeper where you park and pretend you live there for the rest of the day, then get a beauty sleep and sleep in til freakin 5... 6... 7 isn’t how truck drivers do it. That’s how the driving school graduates do it. ","replyToPid":0}
GMT+8, 2026-4-18 01:35 , Processed in 0.145206 second(s), 24 queries .
