查看: 446|回复: 37
Another wonderful day in NYC
 楼主| 发表于 2020-1-25 05:43:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"Traffic is F'd more than normal due to a crash, of course, in the center lane","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1102.0,\"name\":\"\",\"url\":\"\",\"width\":826.0}]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-1-25 07:28:19 来自手机 | 显示全部楼层
848274 发表于 2020-01-24 23:25:39 you know the drill.\nI'm home till Monday I believe
","text":"👍","replyToPid":312026}
发表于 2020-1-25 07:30:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe you should cry about it ","replyToPid":0}
 楼主| 发表于 2020-1-25 07:48:59 来自手机 | 显示全部楼层
764424 发表于 2020-01-24 23:42:54 Trucking seems too tough for you. Maybe you should try being a greeter at Walmart.
","text":"I've most likely been at it longer than you.  But of course you can keep working as the water taster at your water treatment plant...I heard that you get all the brown trout you can eat","replyToPid":312033}
 楼主| 发表于 2020-1-25 06:35:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"From one sh!t  state to another ","replyToPid":0}
发表于 2020-1-25 10:17:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"them nyc 4 wheelers are the nastiest sumbıtchĕs ..they would rather speed up and cause a wreck them ever let a truck merge in front of them","replyToPid":0}
发表于 2020-1-25 11:45:27 来自手机 | 显示全部楼层
😉 of course. The warmer temps are just bonus.
{"replyToPid":312112,"replyTo":"
884191 发表于 2020-01-25 02:51:09 😉 of course. The warmer temps are just bonus.
","text":"you probably say that to all the boys🤣"}
发表于 2020-1-25 06:41:27 来自手机 | 显示全部楼层
674254 发表于 2020-01-24 22:35:15 From one sh!t  state to another
","text":"ny is the best sh*t state","replyToPid":312003}
发表于 2020-1-25 06:52:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Should've taken I-287 to bypass NYC","replyToPid":0}
 楼主| 发表于 2020-1-25 07:39:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"You're most likely one of the rude a$$es that reside in one of those 💩states","replyToPid":0}
发表于 2020-1-25 07:12:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"master-bate I mean meditate","replyToPid":0}
发表于 2020-1-25 06:08:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good lock","replyToPid":0}
 楼主| 发表于 2020-1-25 06:09:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"No doubt...patience is running thin","replyToPid":311989}
发表于 2020-1-25 06:20:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"hopefully don't end up sitting there too long be safe good luck","replyToPid":0}
 楼主| 发表于 2020-1-25 06:42:16 来自手机 | 显示全部楼层
553650 发表于 2020-01-24 22:41:27 ny is the best sh*t state
","text":"The flem pile state ","replyToPid":312004}
 楼主| 发表于 2020-1-25 07:24:18 来自手机 | 显示全部楼层
848274 发表于 2020-01-24 23:12:04 master-bate I mean meditate
","text":"🥒💦🤣🤣","replyToPid":312010}
GMT+8, 2026-4-18 18:43 , Processed in 0.089100 second(s), 24 queries .
