查看: 112|回复: 7
any suggestions?
 楼主| 发表于 2020-1-24 16:23:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"having an issue with windshield washer pump....keeps on running...emptied the reservoir.\nsuggestions?\nrelay or pump?\nI am close to Yakima WA on my way East,...","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-24 17:01:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"replace it","replyToPid":0}
发表于 2020-1-24 19:53:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"If weather is good. Pull the fuse and prey you don’t get inspected. \n\n","replyToPid":0}
发表于 2020-1-24 22:44:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fill the reservoir with likwuid shicken ","replyToPid":0}
发表于 2020-1-24 21:27:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Find the fuse and pull it. Let it stay out as long as you don't need it so it can reset itself","replyToPid":0}
发表于 2020-1-24 21:44:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"windex bottle squirt it into the switch work the switch in out up down it'll loosen it up problem solved","replyToPid":0}
发表于 2020-1-25 09:32:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unplug the pump!","replyToPid":0}
发表于 2020-1-25 09:49:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Look just put a wet towel over your wipers.when you need to clean your windshield, towels wet and you start the wipe on wipe off training. It’s towel, I’ve seen it done before,","replyToPid":0}
GMT+8, 2026-4-18 18:42 , Processed in 0.087602 second(s), 24 queries .
