查看: 155|回复: 5
Load boards vs broker which is better? And most of the loads posted on the load boards do they show pick up and droptime
 楼主| 发表于 2020-1-24 00:44:58 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-1-24 01:23:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"You are using a broker when using a load board. On rare occasions,  the shipper will post a load directly.   As far as pick up and drop off times being posted, they'll usually give the p/u and d/o dates.  Only when you book the load will you get all of the load info.","replyToPid":0}
发表于 2020-1-24 01:21:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"they usually do","replyToPid":0}
 楼主| 发表于 2020-1-24 01:32:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok thanks","replyToPid":311200}
 楼主| 发表于 2020-1-24 01:32:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok thanks","replyToPid":311210}
发表于 2020-1-24 03:09:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I prefer to cultivate good relationships with a couple brokers and work directly with them. If they have slow times then I search the boards.\nAbout 95 percent of the good paying freight in my category never hits any load board.\nRight now it feels like brokers are throwing out their low bottom feeder rates on a load board and trolling along, hoping to reel in a sucker.","replyToPid":0}
GMT+8, 2026-4-18 03:23 , Processed in 0.087222 second(s), 24 queries .
