查看: 164|回复: 10
Diesel fuel
 楼主| 发表于 2020-1-23 12:22:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone with a Cat engine have problems with Loves fuel?\nSeems like it don't have enough power (energy) in their fuel.\nTruck is sluggish and fuel mileage is horrible.\nIf I run the tanks all the way down and fuel somewhere else, I don't have that problem.\nSo I know it's not a mechanical problem. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-23 21:33:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used to haul loves fuel. Whyoming, Colorado, Kansas, Nebraska and Utah all pull from the same refinery spouts as everyone else. 🤦‍♂️","replyToPid":0}
发表于 2020-1-23 21:19:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"They have low grade fuel biofuels don’t have anything to do with it we have it up north and that’s all you can buy ","replyToPid":0}
发表于 2020-1-24 00:31:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds like their fuel is too big for your filter. I'd throw a bigger micron in just to see","replyToPid":0}
发表于 2020-1-23 21:26:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"how far up north are you? I am in WNY and have more options than bio fuel","replyToPid":0}
发表于 2020-1-23 17:26:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always check before fill up diesel type. Do not use biodiesel","replyToPid":0}
 楼主| 发表于 2020-1-24 10:21:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"So, does anyone HAVE A CAT ENGINE and have had power issues with Loves fuel?\nNot asking about bio, microns, or anything else other than the question I asked... Pretty simple, if you don't have a Cat engine or haven't had one recently... You can't answer the question.","replyToPid":0}
 楼主| 发表于 2020-1-24 10:17:31 来自手机 | 显示全部楼层
648759 发表于 2020-01-23 09:26:23 Always check before fill up diesel type. Do not use biodiesel
","text":"Unfortunately, places without bio are far and few in between","replyToPid":310854}
 楼主| 发表于 2020-1-24 10:19:26 来自手机 | 显示全部楼层
553636 发表于 2020-01-23 16:31:33 Sounds like their fuel is too big for your filter. I'd throw a bigger micron in just to see
","text":"I run a cat engine with cat filters.\nI don't use large micron filters because I don't want junk getting to my injectors.","replyToPid":311151}
发表于 2020-1-24 10:22:08 来自手机 | 显示全部楼层
211886 发表于 2020-01-24 02:19:26 I run a cat engine with cat filters.\nI don't use large micron filters because I don't want junk getting to my injectors.
","text":"I hear you there","replyToPid":311457}
GMT+8, 2026-2-14 20:43 , Processed in 0.061519 second(s), 24 queries .
