查看: 158|回复: 4
Swift earns the reputation
 楼主| 发表于 2020-1-23 06:33:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"Ok so this is why Swift drivers are relentlessly singled out.. today at a relatively small customer I'm waiting for a door to become available. Here comes Swift (female African American driver) The are 4 open slots.  She lines up for spot next to me. After 20 minutes of working her tractor nose from the left to the right side of the parking lot she finishes mid lane and parks. wtf!\n","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1512.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true,"externalShare":false}
发表于 2020-1-23 09:26:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"so guess this isnt ok because she is a black female and if she had been say a white male it would be ok. w t f is wrong with you. why would her race or gender need to be labeled in this unless you were against african americans or woman or both. smh. so she took two spots get over it. she wasnt hurting you. jerk.","replyToPid":0}
回复 支持 4 反对 2
发表于 2020-1-23 09:28:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"did you stop to help her in her 20 mins of struggle? no you sat on your a$$ and watched. maybe shes new and shes trying her best. was she in the wrong for taking two stops yes but she her race and gender need to be pointed out no. get over yourself. i see worse at shippers all the time. as least someone could still park.","replyToPid":0}
回复 支持 3 反对 2
发表于 2020-1-23 08:58:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"It could've been worse: your hood wasn't taken off the truck.","replyToPid":0}
发表于 2020-1-23 11:20:30 来自手机 | 显示全部楼层
836417 发表于 2020-01-23 01:28:08 did you stop to help her in her 20 mins of struggle? no you sat on your a$$ and watched. maybe shes new and shes trying her best. was she in the wrong for taking two stops yes but she her race and gender need to be pointed out no. get over yourself. i see worse at shippers all the time. as least someone could still park.
","text":"Well Said... \n\nCheers!","replyToPid":310512}
GMT+8, 2026-4-17 01:08 , Processed in 0.081264 second(s), 24 queries .
