查看: 141|回复: 18
Pringle’s diameter
 楼主| 发表于 2020-1-21 23:31:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"Has anyone ever noticed that the outer edge of a Pringle’s potato chip is the same diameter as the can it comes in? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-22 00:35:05 来自手机 | 显示全部楼层
834825 发表于 2020-01-21 16:29:15 I'm not going to go out and buy a can of Pringles just to find out...
","text":"But the cans work so good for storing zip ties and load seals","replyToPid":309531}
发表于 2020-1-22 00:52:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"My lips are sealed on the seals mingling with the ties 🤐","replyToPid":0}
发表于 2020-1-21 23:57:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s slightly smaller so it fits inside the container, simpleton. 😂","replyToPid":0}
发表于 2020-1-22 00:48:22 来自手机 | 显示全部楼层
780067 发表于 2020-01-21 16:35:05 But the cans work so good for storing zip ties and load seals
","text":"as usual you have injected unassailable logic into the conversation... But I hope you are not storing zip ties and load seals in the same can!!","replyToPid":309535}
发表于 2020-1-22 00:12:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"now I can sleep knowing that","replyToPid":0}
发表于 2020-1-22 02:03:52 来自手机 | 显示全部楼层
235536 发表于 2020-01-21 16:35:41 I think someone has to much time on there hand's
","text":"Their ","replyToPid":309537}
发表于 2020-1-22 00:29:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm not going to go out and buy a can of Pringles just to find out...","replyToPid":0}
发表于 2020-1-22 01:44:03 来自手机 | 显示全部楼层
730796 发表于 2020-01-21 17:37:25 No, duck face, one is inside diameter and the other is outside diameter- same number
","text":"If it was the same then the chip would have to be merged into the cardboard that makes the body of the container therefore rendering it an inedible product. I’d suggest that you not trust your brain very much when it comes to physics or anything technical. Just keep it basic and we won’t have to be dumber for reading your random inaccurate observations about things no one cares about. 🤣","replyToPid":309564}
发表于 2020-1-22 00:58:11 来自手机 | 显示全部楼层
780067 发表于 2020-01-21 16:52:32 My lips are sealed on the seals mingling with the ties 🤐
","text":"It’s okay, they’re probably greasy 😉","replyToPid":309553}
发表于 2020-1-21 23:58:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"No potato in Pringle’s ","replyToPid":0}
发表于 2020-1-21 23:57:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"once you pop you cant stop","replyToPid":0}
发表于 2020-1-22 00:35:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think someone has to much time on there hand's","replyToPid":0}
GMT+8, 2026-2-14 23:50 , Processed in 0.081040 second(s), 24 queries .
