查看: 342|回复: 17
Can someone explain me how long can I drive in OFF duty personal Conveyance mode is there's no parking?
 楼主| 发表于 2020-1-21 00:44:29 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-1-21 00:54:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"from what I understand it's to the closest available safe haven regardless of whether its along the route or not","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-1-21 01:20:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"According to FMCSA there are no time or distance maximums. The driver just has to make sure they get adequate rest before returning to work.","replyToPid":0}
发表于 2020-1-21 00:56:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"to the closest safe haven. if you're not going in direction of the delivery or pick up you can drive pc for however long you want so long as you have reason to.  for example going for food or something recreational of that sort.","replyToPid":0}
 楼主| 发表于 2020-1-21 00:48:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Because from what I understand is that as long as I'm not physically in derate mode and there's no safe parking available.","replyToPid":0}
 楼主| 发表于 2020-1-21 02:20:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"That's would be dumb to drive back home.","replyToPid":0}
发表于 2020-1-21 03:24:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"FMCSA states that if you run out of hours at a shipper/receiver, you can drive in any direction to reach a safe haven, no imposed time or distance has been placed on it. As far as standard personal conveyance, if you are unladen, not headed to a pickup and not being paid, then you can go as far as you need. I've used PC from Roanoke VA to Scranton PA, stopped at Winchester scales and once on I81 by DOT, neither officer had issues with my log. If you want more clarification... Google it.","replyToPid":0}
发表于 2020-1-21 18:18:55 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Until you find parking...as long as it takes but you can’t pass one just because you don’t like the local and you can’t be advancing your load."}
发表于 2020-1-21 12:07:48 来自手机 | 显示全部楼层
628161 发表于 2020-01-20 16:56:53 to the closest safe haven. if you're not going in direction of the delivery or pick up you can drive pc for however long you want so long as you have reason to.  for example going for food or something recreational of that sort.
","text":"Per Dot 50 miles","replyToPid":308450}
发表于 2020-1-21 06:53:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"what does your company allow you? company drivers usually only.get an hour","replyToPid":0}
发表于 2020-1-22 11:31:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Forever ","replyToPid":0}
发表于 2020-1-21 01:03:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"forever","replyToPid":0}
发表于 2020-1-21 01:23:53 来自手机 | 显示全部楼层
{"replyToPid":308469,"replyTo":"
901522 发表于 2020-01-20 17:20:23 According to FMCSA there are no time or distance maximums. The driver just has to make sure they get adequate rest before returning to work.
","text":"But in this example, you have to drive to the nearest safe haven, even if it is in the other direction.."}
发表于 2020-1-21 02:06:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think  you get 60km or 70km for personal driving.","replyToPid":0}
 楼主| 发表于 2020-1-21 02:23:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you everyone for answering. That clears a lot of misunderstanding.","replyToPid":0}
GMT+8, 2026-2-16 07:36 , Processed in 0.117424 second(s), 24 queries .
