查看: 298|回复: 15
$50.00 for a ride. STRANDED ON I-80 mm 88 wb
 楼主| 发表于 2020-1-20 04:13:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"We been stuck here at mm 88 on I-80 in Iowa. Need a ride to go get a gallon of fuel from the Casey's at mm 93 and back to my truck $50","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-20 05:19:27 来自手机 | 显示全部楼层
回复 支持 4 反对 1
发表于 2020-1-20 05:42:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Call 911, DOT and tell them that your company is forcing you to drive until you're out of fuel due to tight HOS regulations.","replyToPid":0}
发表于 2020-1-20 04:28:34 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You won't start a diesel truck on 1 gallon of fuel, call T/A they will bring fuel to you. Loves will bring fuel as well. Buy a can of starting fluid. You will need it to prime pump/fuel system."}
发表于 2020-1-20 08:51:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"make sure you put a half gallon in each tank","replyToPid":0}
发表于 2020-1-20 06:17:34 来自手机 | 显示全部楼层
633306 发表于 2020-01-19 21:01:19 Can’t you look at him and tell why he ran out of fuel ⛽️
","text":"🤔😆👍","replyToPid":307920}
发表于 2020-1-20 16:03:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I ran out of fuel before because of a wacky fuel gauge when that hydraulic pump stops working it's super hard to guide the truck off the road","replyToPid":0}
发表于 2020-1-20 18:31:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I run out of fuel on the exit ramp to the Love’s east of Amarillo with a load of feeder cattle on. Carried a couple jugs of diesel to my truck then made it to the fuel island and topped it off. With Cummins it’s easy to get going again. Don’t have to do anything with the filters like those prehistoric CAT engines 😂 ","replyToPid":0}
发表于 2020-1-20 07:59:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"you could walk, it's only 5 miles","replyToPid":0}
发表于 2020-1-20 04:36:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why did you run out of fuel ⛽️?","replyToPid":0}
发表于 2020-1-20 06:01:19 来自手机 | 显示全部楼层
626560 发表于 2020-01-19 21:50:55 Dammit Driver, I thought I was tough sometimes. That comment  took the cake today!
","text":"He learned a good one lesson today","replyToPid":307952}
发表于 2020-1-20 05:50:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dammit Driver, I thought I was tough sometimes. That comment  took the cake today!","replyToPid":0}
发表于 2020-1-20 05:50:55 来自手机 | 显示全部楼层
880983 发表于 2020-01-19 21:19:27 Hope your arms ready for pushing the primer pump. \n\nWhat did you learn? \nThat trucks need push water and there is a gauge on the dash to tell you how much you have. \n\nWhen the gauge is empty. \nYou pull into a magical place called a fuel island. \n\nIf you don’t know what to do from there........  stop everything and make sure your breathing. \n\nIf you still need help. Lick the face of the first person you see. Help will be on the way
","text":"Dammit Driver, I thought I was tough sometimes. That comment  took the cake today!","replyToPid":307927}
发表于 2020-1-20 06:16:27 来自手机 | 显示全部楼层
","text":"👍","replyToPid":307927}
GMT+8, 2026-2-16 07:37 , Processed in 0.075801 second(s), 24 queries .
