查看: 320|回复: 12
No ELD anymore 😢😢😢 No kidding. What a disappointment! No 34 restarts anymore, no 10 h sleep 😥😥😥
 楼主| 发表于 2020-1-20 03:14:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"Fake ELD 😢😢😢","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-23 13:38:21 来自手机 | 显示全部楼层
894242 发表于 2020-01-23 05:25:24 I dont understand? But isn't the driver the one driving?
","text":"What he means is boss tells you where to go, DOT says the rules to follow to get there. You just have to able to stand up for yourself in instances where your not gonna cross paths the wrong way with either of them. Called being a professional driver,","replyToPid":310799}
发表于 2020-1-20 07:19:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok since there’s no reply, I’m going off based what I see and I’ve been Tru. I can only answer half, thus being said. \nThe log edits are from your employer asking you to approve the adjustments THEY have made in order for you to be pushed to your max on time. Which is illegal, only driver can edit his logs as he is the only one working. As far as the 34 restarts and 10 hr sleep idk. Gonna have to wait on the response","replyToPid":0}
 楼主| 发表于 2020-1-25 05:06:38 来自手机 | 显示全部楼层
","text":"DOT and HOS are as well as other so called legal restrictions aren't there for safety but to reduce competition for companies like SWIFT and CR ENGLAND while in reality those companies produce new drivers every day which adds more danger to public safety than public can possibly imagine. You better read how C.R. England came into business and ask your local authorities to allow you selling bananas from the back of your trailer.","replyToPid":310799}
发表于 2020-1-23 12:40:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t approve any adjustments until they tell you what it is, why they did it and more importantly why didn’t they notify you first and foremost. One reason I left a company last year for doing this. I gave them The ok but man if DOT gotta hold of my logs from back then company would be in some serious 💩. Needs to be in control of the driver but to a point. Some of “ us” abuse it to the max and ruin it for everybody else that’s using log edits correctly.","replyToPid":0}
发表于 2020-1-21 03:37:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was using master safety AOBRD last year for a week while my truck was in the shop. I normally use paper, but I was stopped at Utah scales and he pulled up inspection module and could see all corrections made by company. I am an O/O but the guy I am leased to let me use a spare truck, and because he had corrected a 7 minute \"over drive time of 11 hrs\", my company received a $1500 fine. DOT can see all that now on ELD, it's risky to accept \"corrections\".","replyToPid":0}
发表于 2020-1-23 13:25:24 来自手机 | 显示全部楼层
695193 发表于 2020-01-20 04:12:02 Driver can't approve anything here. Driver is in a middle between DOT and the Boss.
","text":"I dont understand? But isn't the driver the one driving?","replyToPid":308100}
发表于 2020-1-20 06:58:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"same..☝️","replyToPid":0}
发表于 2020-1-20 06:53:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"What’s going on here? Details driver, you have peaked my interest. ","replyToPid":0}
 楼主| 发表于 2020-1-20 12:12:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Driver can't approve anything here. Driver is in a middle between DOT and the Boss.","replyToPid":0}
 楼主| 发表于 2020-1-20 12:17:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"And Driver can't see anything until he pushes approve button.","replyToPid":0}
发表于 2020-1-21 05:11:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"find a new company or use it to your advantage $$$","replyToPid":0}
GMT+8, 2026-2-8 05:56 , Processed in 0.083171 second(s), 24 queries .
