查看: 224|回复: 17
trying to get blood pressure down to pass orientation somewhere
 楼主| 发表于 2020-1-19 13:47:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"I've been sent home from orientation at Knight , Schneider National, US Express, Melton.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1632.0,\"name\":\"\",\"url\":\"\",\"width\":1224.0}]","canComment":true,"externalShare":false}
发表于 2020-1-19 20:53:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"You should see your doctor, it may be that you have to go on meds to control it ","replyToPid":0}
发表于 2020-1-19 15:12:05 来自手机 | 显示全部楼层
871835 发表于 2020-01-19 06:47:27 That should tell you something.
","text":"yeah I'm pretty sure taking a walk once in awhile would help.","replyToPid":307534}
发表于 2020-1-19 14:47:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"That should tell you something.","replyToPid":0}
发表于 2020-1-20 00:48:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"So it sounds like your just trying to pass  orientation and not look for a long term solution, be that as it may, but long term program would be ideal. \n\nRather then pop a pill, maybe look at goals and short term achievements to find a permanent solution to your issue.  \n\nIf your BP is not even at a acceptable limit for a 3 month temp med card, is it really worth the risk to further elevate risking harm to yourself and the general motoring Public?\n\nCheers!","replyToPid":0}
发表于 2020-1-19 23:18:49 来自手机 | 显示全部楼层
610123 发表于 2020-01-19 12:44:55 It is common for trolls to have uncontrollable high blood pressure 😉
","text":"that's from living under bridges","replyToPid":307597}
发表于 2020-1-19 20:44:55 来自手机 | 显示全部楼层
626560 发表于 2020-01-19 08:24:24 So, what's your deal? \n\nYou have posted many a time and can't seem to get it straight. \n\nAre you over weight?\nAddicted  to sugar? \nA troll??\n\n\nCheers!
","text":"It is common for trolls to have uncontrollable high blood pressure 😉","replyToPid":307562}
发表于 2020-1-19 16:24:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"So, what's your deal? \n\nYou have posted many a time and can't seem to get it straight. \n\nAre you over weight?\nAddicted  to sugar? \nA troll??\n\n\nCheers!","replyToPid":0}
发表于 2020-1-19 21:43:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah, you gotta get on blood pressure meds, man. Also pop a couple of Xanax, they calm you down and a standard five panel DOT test doesn’t check for benzos ","replyToPid":0}
发表于 2020-1-20 00:51:33 来自手机 | 显示全部楼层
","text":"Way to many Hobbits in his diet...","replyToPid":307597}
发表于 2020-1-19 16:07:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"No quick, easy fix. Use NoSalt. It is a replacement for regular salt. It uses Potassium Chloride. It will help dump some fluid and maybe help your heart. Ultimately, you will need meds. Your doctor will be able to help best.","replyToPid":0}
发表于 2020-1-19 16:44:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"perindopril.  just get proper blood pressure meds while you work on lifestyle stuff.","replyToPid":0}
发表于 2020-1-19 21:36:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Start exercising, again. Your health will thank ya for it.","replyToPid":0}
GMT+8, 2026-2-16 07:37 , Processed in 0.081573 second(s), 24 queries .
