查看: 281|回复: 15
new to trucking
 楼主| 发表于 2020-1-19 10:00:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"how many miles to the gallon do the flat nose 379 or 389 get I'm doing my training in a 579 peterbilt but what a flat nose I'm currently getting 8 to 12 mpg are the flat nose better or worse","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-19 20:38:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ain’t no dam way your getting 8-12 mpg!!!!!!","replyToPid":0}
发表于 2020-1-20 02:58:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"he's bobtailing that Pete pulling them mpg's","replyToPid":0}
 楼主| 发表于 2020-1-20 03:28:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"ok let's make this more clear I Bob tail get 12 mpg when I'm fully loaded I get 5 to 8 mpg","replyToPid":0}
发表于 2020-1-20 04:41:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your getting 8 to 12 mpg you better gold plate That truck ","replyToPid":0}
发表于 2020-1-20 03:13:56 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"A 2019 Cascadia with DD15 capped @ 70mph with the transmission in economy mode barely gets 9mpg on its best day. 12 in a flat nose Pete? Don’t believe it. "}
发表于 2020-1-19 21:34:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"U got a whole bunch of other factors to think about than thinking about a flat nose for fuel economy.","replyToPid":0}
发表于 2020-1-20 04:45:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Liar","replyToPid":0}
发表于 2020-1-19 16:16:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Stick your face out the driver side window and you will get better mpg.. \n\nCheers....","replyToPid":0}
发表于 2020-1-19 20:52:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"goo too check google map 🤣🤣🤣","replyToPid":0}
发表于 2020-1-19 21:29:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'll believe those numbers going down Monteagle","replyToPid":0}
发表于 2020-1-19 22:10:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"u r not getting 8-12 mpg , i run a bmodel all mechanic cat in a 379 and average 6 mpg pullin tanker can get 6.3 in summer and 5.7 in winter all depends, ","replyToPid":0}
GMT+8, 2026-4-18 20:05 , Processed in 0.131633 second(s), 24 queries .
