查看: 131|回复: 14
Minnesota and North Dakota
 楼主| 发表于 2020-1-19 10:00:38 来自手机 | 显示全部楼层 |阅读模式
{"text":"Roads are very icy. I-94 and I-29 closed at Fargo ND.\nDrive carefully everyone. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":980.0}]","canComment":true,"externalShare":false}
发表于 2020-1-19 10:10:14 来自手机 | 显示全部楼层
60662 发表于 2020-01-19 02:08:28 Thank you. \n I pulled the plug for the night. Kind of a  lousy way to start the trip. only 180 miles. What do they say. Better safe than sorry.
","text":"Yep. That's what they say","replyToPid":307421}
发表于 2020-1-19 10:04:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Be safe brother ","replyToPid":0}
 楼主| 发表于 2020-1-19 10:08:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you. \n I pulled the plug for the night. Kind of a  lousy way to start the trip. only 180 miles. What do they say. Better safe than sorry.","replyToPid":307418}
发表于 2020-1-19 10:23:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Safe man ","replyToPid":0}
发表于 2020-1-19 10:15:08 来自手机 | 显示全部楼层
","text":"Glad you're tucked away safe for the night. Be careful in the morning, and thanks for the heads up","replyToPid":307421}
发表于 2020-1-19 10:48:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep we had a great 2 day storm ","replyToPid":0}
发表于 2020-1-19 10:39:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'll be right behind you","replyToPid":0}
发表于 2020-1-19 10:57:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok I live 130 miles south of there it’s cold but wind went down ","replyToPid":0}
发表于 2020-1-23 13:27:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"You welcome ","replyToPid":0}
 楼主| 发表于 2020-1-19 11:08:31 来自手机 | 显示全部楼层
295387 发表于 2020-01-19 02:57:54 Ok I live 130 miles south of there it’s cold but wind went down
","text":"I live in Kimball, called home was told wind has died down alot. I've already been parked a little over 2 hours. Walmart is filling up. but still plenty of room.","replyToPid":307462}
 楼主| 发表于 2020-1-19 10:34:59 来自手机 | 显示全部楼层
780067 发表于 2020-01-19 02:15:08 Glad you're tucked away safe for the night. Be careful in the morning, and thanks for the heads up
","text":"thank you","replyToPid":307425}
 楼主| 发表于 2020-1-19 10:35:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you.","replyToPid":307435}
 楼主| 发表于 2020-1-19 10:44:19 来自手机 | 显示全部楼层
103619 发表于 2020-01-19 02:39:39 I'll be right behind you
","text":"There were times while I was still empty that my truck was hitting the rumble strip on the center line and trailer was on the rumble strip on the shoulder fog line.\nthat was on hwy 15 around noon. drive safe","replyToPid":307452}
GMT+8, 2026-2-14 22:15 , Processed in 0.065517 second(s), 24 queries .
