查看: 186|回复: 2
Mornin, Are you required to log on paper for 8 days after an ELD malfunction or just go back to the ELD when it's fixed?
 楼主| 发表于 2020-1-17 01:32:34 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-1-17 02:07:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nope. Just keep using the ELD once it’s fixed and manually add in what you logged on paper. Once you approve your logs it will upload to the servers and be saved for you. No need to keep using paper. ","replyToPid":0}
 楼主| 发表于 2020-1-17 02:09:06 来自手机 | 显示全部楼层
497499 发表于 2020-01-16 18:07:03 Nope. Just keep using the ELD once it’s fixed and manually add in what you logged on paper. Once you approve your logs it will upload to the servers and be saved for you. No need to keep using paper.
","text":"great... thank you","replyToPid":306605}
GMT+8, 2026-2-4 06:19 , Processed in 0.080476 second(s), 24 queries .
