查看: 233|回复: 9
I-10 WB Louisiana mm8
 楼主| 发表于 2020-1-16 10:16:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"Major wreck at mm2 West bound in Louisiana, all lanes closed. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":992.0,\"name\":\"\",\"url\":\"\",\"width\":744.0}]","canComment":true,"externalShare":false}
发表于 2020-1-16 11:50:05 来自手机 | 显示全部楼层
888546 发表于 2020-01-16 03:49:26 I remember my first rail of meth. I figure, it's white and same as coke. Three days later I'm still awake and rewiring my dashboard for no reason.
","text":"I couldn't stop beating it. raw for weeks.","replyToPid":306134}
发表于 2020-1-16 11:26:36 来自手机 | 显示全部楼层
888546 发表于 2020-01-16 02:20:35 2 7/8 drill pipe in front of you. Take HWY 190 if you can get to an exit.
","text":"Yeah 90 is your best bet to get around from there.","replyToPid":305976}
发表于 2020-1-16 11:38:46 来自手机 | 显示全部楼层
848274 发表于 2020-01-16 03:38:10 you sure know you're \"PIPE\" 🐔🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣
","text":"Only a tool would know","replyToPid":306110}
发表于 2020-1-16 11:53:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"haha was that the railroad work?","replyToPid":0}
发表于 2020-1-16 12:40:38 来自手机 | 显示全部楼层
848274 发表于 2020-01-16 04:39:04 apparently you're not very good at this.  laying down rails for the railroad is laying facedown on your stomach while they run a 🚞 all ip in your 💩.. get a better playbook
","text":"How many trains have you had.  did they rub your bald head while running?","replyToPid":306218}
发表于 2020-1-16 12:48:42 来自手机 | 显示全部楼层
848274 发表于 2020-01-16 04:45:45 I'm the conductor whereas you're the cumdumpster
","text":"hahaha your gayer than I pretend to be","replyToPid":306228}
发表于 2020-1-16 12:56:27 来自手机 | 显示全部楼层
848274 发表于 2020-01-16 04:55:18 I can play pretty hard.  problem is you'll probably get hard. they say it's all fun and games until you get a 🦴R
","text":"been hard for weeks wont go down until I quit hitting the bulb?  what's your exscuse?","replyToPid":306239}
发表于 2020-1-16 13:01:44 来自手机 | 显示全部楼层
848274 发表于 2020-01-16 05:00:05 totally out of context.  I'll go back to remedial joking for you
","text":"ok good between the 3 of us chickens we confuse easily","replyToPid":306247}
发表于 2020-1-17 00:22:32 来自手机 | 显示全部楼层
","text":"😂😂😂","replyToPid":306134}
GMT+8, 2026-4-15 01:09 , Processed in 0.139885 second(s), 24 queries .
