查看: 475|回复: 10
Ticket / warning
 楼主| 发表于 2020-1-15 09:22:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"If you get pulled over and an officer gave you a warning instead of a ticket; Can you tell the officer you would like a ticket instead, so you can fight it? Do you have that option cause I don’t know and I would like the ticket if I was in that position. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-15 11:19:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"The answer is YES , you can ask for a citation instead of a warning, I do it every time 90% you will get you’re ticket dismissed in court but a warning will go against you’re CSA score , I joined TVC and they have been good so far no issues  . Got a ticket in my car and they got it dismissed for me . Check them out and good luck ! ","replyToPid":0}
发表于 2020-1-15 11:11:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is this rite? If it impacts your score what’s the point of calling it a warning? Should be a ticket if affects the license holder in any way, - I’m a lawyer ","replyToPid":0}
发表于 2020-1-15 10:11:27 来自手机 | 显示全部楼层
871816 发表于 2020-01-15 01:28:09 warning is pretty much just as bad as ticket except you can fight a warning .
","text":"You can fight a ticket because there are consequences,  however, the only consequence with a warning is too many of them impacts you negatively on future stops.","replyToPid":305330}
发表于 2020-1-15 18:59:47 来自手机 | 显示全部楼层
{"replyToPid":305412,"replyTo":"
103619 发表于 2020-01-15 04:41:47 educate yourself..... \n\n\n\nThere are basically three kinds of citations (tickets) issued for moving violations.\n1) Standard traffic ticket. Will mean you pay a fine and it goes on you driving record unless you successfully fight it.\n\n2) Warning traffic ticket. Means just that it is a warning. It means you have been given written notice to remove your head from your back side and drive properly. There is no penalty other than the hassle of being stopped and the waste of time.\n\n3) Fix it traffic ticket. Not really issued for a moving violation, but often times will be issued if the cop decides to not write you for a moving violation but wants you to get something fixed on your car. These can be taken care of by getting the problem fixed and having either the mechanic or a LEO, depending on your jurisdiction's rules and regs sign the ticket off.\n\nThese are your standard traffic tickets and may or may NOT be related to DOT rules and regs.
","text":"So, in this context, we are talking about DOT violations.  A warning DOES affect your CSA score like a conviction.  \n\nTraffic stops are a different thing altogether.  Hopefully the OP understands this is a forum for all things “CMV”"}
发表于 2020-1-15 12:41:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"educate yourself..... \n\n\n\nThere are basically three kinds of citations (tickets) issued for moving violations.\n1) Standard traffic ticket. Will mean you pay a fine and it goes on you driving record unless you successfully fight it.\n\n2) Warning traffic ticket. Means just that it is a warning. It means you have been given written notice to remove your head from your back side and drive properly. There is no penalty other than the hassle of being stopped and the waste of time.\n\n3) Fix it traffic ticket. Not really issued for a moving violation, but often times will be issued if the cop decides to not write you for a moving violation but wants you to get something fixed on your car. These can be taken care of by getting the problem fixed and having either the mechanic or a LEO, depending on your jurisdiction's rules and regs sign the ticket off.\n\nThese are your standard traffic tickets and may or may NOT be related to DOT rules and regs.","replyToPid":0}
发表于 2020-1-15 10:12:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"You mean you cannot fight a warning?\n\nIt’s my understanding that a warning hits your CSA score the same way as a violation. So always ask for the ticket and fight it.  (Or join one of those lawyer subscriptions and have them do it)","replyToPid":0}
发表于 2020-1-16 02:56:20 来自手机 | 显示全部楼层
","text":"I was pulled over in Tennessee and was given a verbal warning,one month later the company came under DOT scrutiny and my verbal was one of the 6 reasons four this.","replyToPid":305412}
发表于 2020-1-15 10:25:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"SMFH","replyToPid":0}
发表于 2020-1-15 09:28:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"warning is pretty much just as bad as ticket except you can fight a warning .","replyToPid":0}
 楼主| 发表于 2020-1-16 00:21:44 来自手机 | 显示全部楼层
{"replyToPid":305391,"replyTo":"
65709 发表于 2020-01-15 03:19:41 The answer is YES , you can ask for a citation instead of a warning, I do it every time 90% you will get you’re ticket dismissed in court but a warning will go against you’re CSA score , I joined TVC and they have been good so far no issues  . Got a ticket in my car and they got it dismissed for me . Check them out and good luck !
","text":"Thanks! I was more so wondering if they would be mean and make you take a ticket instead. Its been a long time since i got a warning and when I first started in training I got a warning and never knew until i could refuse it until I looked into it. "}
GMT+8, 2026-4-17 05:11 , Processed in 0.103253 second(s), 24 queries .
