查看: 569|回复: 59
Why do drivers flash their brights?
 楼主| 发表于 2020-1-15 02:57:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"I don't need your brights. I know how to drive a big truck, I can see you. I'll move over when I feel like it. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-15 08:55:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"So your the slow guy hogging up the hammer lane? 😑😑","replyToPid":0}
回复 支持 9 反对 0
发表于 2020-1-15 09:00:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"probably moves off the fuel island \"When he feels like it\" ...just another Billy the big Rigger","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-1-15 03:04:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Big man!...he’ll rinse the jizz off his face...when he feels like it!🤪🤯🤩","replyToPid":0}
回复 支持 6 反对 1
发表于 2020-1-15 19:08:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe it's the driver showing road courtesy","replyToPid":0}
发表于 2020-1-15 21:19:46 来自手机 | 显示全部楼层
73734 发表于 2020-01-15 02:38:24 It's not necessary, is all I'm saying.
","text":"No one gives a s hit about what you’re saying.... that’s been the courteous thing to do since trucking was trucking.... new breed as shole ","replyToPid":305376}
发表于 2020-1-16 21:31:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"When the weather is bad, windows and mirrors have a tendency of getting dirty, then it becomes hard to tell when you have a safe distance to pull back in.\nuntil the weather clears up you would be cleaning said windows and mirrors every mile or so. \nbottom line courtesy","replyToPid":0}
发表于 2020-1-16 13:36:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"blight?  no that's the blacks who wont go back but complain about everything.","replyToPid":0}
发表于 2020-1-16 08:21:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"No it's not \"necessary\" but it's called common courtesy... Does it upset you if someone holds the door open for you when you walk into the truck stop?\n Do you get pi$$ed off if someone says please or thank you?  After all, those things aren't necessary...Geesh man get off of your high horse....","replyToPid":0}
发表于 2020-1-15 22:01:06 来自手机 | 显示全部楼层
73734 发表于 2020-01-15 13:29:15 That would apply if I hadn't been out here over 12 years, unless you consider that a new driver.
","text":"if that's the case then why would you ask such a rookie question.","replyToPid":305499}
发表于 2020-1-15 21:12:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"to most new Driver's they don't know what road courtesy is that's the problem with most new drivers they just do whatever they want and don't think!","replyToPid":0}
发表于 2020-1-15 03:17:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"So you pull Over and play with my Mini 3rd leg","replyToPid":0}
 楼主| 发表于 2020-1-15 08:31:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I see I see 🤔"}
 楼主| 发表于 2020-1-15 09:56:22 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"."}
 楼主| 发表于 2020-1-15 09:56:50 来自手机 | 显示全部楼层
235536 发表于 2020-01-15 01:00:55 probably moves off the fuel island \"When he feels like it\" ...just another Billy the big Rigger
","text":"Only when you're behind me","replyToPid":305312}
 楼主| 发表于 2020-1-15 10:12:40 来自手机 | 显示全部楼层
发表于 2020-1-15 10:13:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"👍","replyToPid":0}
GMT+8, 2026-2-15 02:53 , Processed in 0.082571 second(s), 24 queries .
