查看: 224|回复: 9
Driveway parking
 楼主| 发表于 2020-1-14 02:19:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Lot is close to empty but they still park along the side blocking the “no parking” signs. they should take the signs down line it out as a reserve spot and charge $30 to 40 a spot forcing them to learn backing up ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":850.0,\"name\":\"\",\"url\":\"\",\"width\":638.0}]","canComment":true,"externalShare":false}
发表于 2020-1-14 06:05:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Driver. \n\nIf the lots empty what do you care?\n\nDo you know when the driver got in? \n\nDid you happen to be there when he or she did pulled and know there were other spots available? \n\nMaybe go and knock on the door, ask that driver to park the way you would prefer? \n\nOr better yet, put on a yellow vest, grab a flashlight and direct trucks to park the way you want... \n\nCheers!","replyToPid":0}
回复 支持 8 反对 1
发表于 2020-1-14 10:08:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Different situation entirely..","replyToPid":0}
发表于 2020-1-14 11:03:36 来自手机 | 显示全部楼层
836417 发表于 2020-01-14 00:47:21 maybe someone took off his hood when he parked in a space and now hes scared and its safer to park there than on side of the highway. i don't go to loves cause a guy blind sided backed into my truck in a middle of the day empty parking lot
","text":"What does that have to do with Loves?","replyToPid":304487}
发表于 2020-1-14 11:02:08 来自手机 | 显示全部楼层
860554 发表于 2020-01-13 20:55:10 crying and worrying about things that in no way, shape or form that affects your day.typical dip 💩 driver nowadays.
","text":"If that were any carrier over 100 trucks you would be signing a different tune wouldn't you?","replyToPid":304355}
发表于 2020-1-14 04:17:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah, that would be one solution.","replyToPid":0}
发表于 2020-1-14 06:17:44 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You, “Howie” (if that is even your real name) are a disgrace to the Feltersnatch name!"}
 楼主| 发表于 2020-1-14 09:03:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"But it does affect my day when I’m trying to back in a spot and there in the way ","replyToPid":0}
 楼主| 发表于 2020-1-14 10:27:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I see most of theses comments for what they are self defense while parked in the driveway I can’t be the only one that’s asked a driver to move to get in or out of a parking spot ","replyToPid":0}
发表于 2020-1-14 11:38:02 来自手机 | 显示全部楼层
626560 发表于 2020-01-13 22:05:24 Driver. \n\nIf the lots empty what do you care?\n\nDo you know when the driver got in? \n\nDid you happen to be there when he or she did pulled and know there were other spots available? \n\nMaybe go and knock on the door, ask that driver to park the way you would prefer? \n\nOr better yet, put on a yellow vest, grab a flashlight and direct trucks to park the way you want... \n\nCheers!
","text":"HAHA!...you’re so funny!...🤣🤣🤣...you always...make me laugh!🤣...I wish we could...hang out and...!...smell each other’s f@rts!🤪🤯🤩","replyToPid":304390}
GMT+8, 2026-4-17 08:39 , Processed in 0.096393 second(s), 24 queries .
