查看: 345|回复: 10
How many times have you driven pass a weigh station even though the signs say open?
 楼主| 发表于 2020-1-12 10:48:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"And how many times have you been caught. lol  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-12 13:07:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"If the ramps full.... 👉","replyToPid":0}
发表于 2020-1-12 10:59:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"At least 3x. I’m so used to getting the bypass notification on my tablet that I usually forget there’s another option 🤣. But I’ve never been stopped. Not saying it’s ok though, because I know quite a few that have received tickets for bypassing a scale. 🤦🏽‍♀️ ","replyToPid":0}
发表于 2020-1-12 11:34:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Happened a couple times. But never came after me ","replyToPid":0}
发表于 2020-1-12 11:40:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've only passed a couple. never been stopped myself. but this past week I was going through an inspection and watched one of the officers go after a truck that didnt stop.","replyToPid":0}
发表于 2020-1-12 11:52:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Minnesota scale on I94 in Lakeland in the last 6 weeks been through that scale and I am going through the scale seen 4 trucks blow right past separate times with no chase down.","replyToPid":0}
发表于 2020-1-12 14:07:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've done it 4 times in the past 3 years but I've never been caught, my logic is if there's three trucks on the entry ramp at the regulated 100 feet you're supposed to stay back from the truck ahead of you then the ramp is full and if the ramp is full you get to bypass I feel like if you run the weigh station and get pulled over and they don't find anything to violate you for then bypassing the weigh station because the on ramp was full is a strong case. because full my full is different than the next person's full and the DOT doesn't specify exactly how many trucks count as \"full\". Just my two cents though, I wouldn't make a habit of it but loopholes are everywhere if you look hard enough","replyToPid":0}
发表于 2020-1-12 18:34:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"NONE & I want them to try. 😈😬","replyToPid":0}
发表于 2020-1-13 11:50:15 来自手机 | 显示全部楼层
742608 发表于 2020-01-12 02:59:12 At least 3x. I’m so used to getting the bypass notification on my tablet that I usually forget there’s another option 🤣. But I’ve never been stopped. Not saying it’s ok though, because I know quite a few that have received tickets for bypassing a scale. 🤦🏽‍♀️
","text":"Yeah, same for me, got a ticket in Kansas for $4500, so not bad at all.  ","replyToPid":303093}
发表于 2020-1-21 04:59:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only when the ramps are full, except one time I was 89000 and TP said the Coop was locked up. CB said the same thing, so I laid the hammer down and OPEN. I never checked up and never had any bubble wrap in the mirror. Heart rate was significantly more than usual ","replyToPid":0}
GMT+8, 2026-4-18 03:23 , Processed in 0.093291 second(s), 24 queries .
