查看: 135|回复: 7
For those who has a TV mounted on that swivel stand in your truck
 楼主| 发表于 2020-1-12 10:47:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"What size is the TV? Can you recomend some do's and dont's of putting a TV in the truck.  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-12 13:15:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"With new eld rules I put 32 inches smart tv in my sleeper. Router from Verizon $65 prepaid and everything works just like at home \nHelp me to wait 10 hours ","replyToPid":0}
发表于 2020-1-12 21:22:41 来自手机 | 显示全部楼层
724453 发表于 2020-01-12 05:57:36 I've seen a video on youtube where a driver mounted a 40 inch using a normal wall mount and the sleeper vent screws that's probably the biggest you'll be able to get in there
","text":"that's what I have","replyToPid":303287}
发表于 2020-1-12 13:57:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've seen a video on youtube where a driver mounted a 40 inch using a normal wall mount and the sleeper vent screws that's probably the biggest you'll be able to get in there","replyToPid":0}
发表于 2020-1-12 13:19:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"I drive a 2020 Kenworth T680 which came with a swivel mount attached to the wall. Also, the mount has a lock mechanism to keep the tv in place while driving. I currently have a 24” tv I bought from Walmart which fits just fine and came with mount screws. A far as what to do and not do, I don’t have much advice since I only had this tv for a month. What I will say is keep your swivel mount locked in place when you’re driving to prevent untreated movement/damage to your tv. ","replyToPid":0}
发表于 2020-1-12 14:15:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fridge is always in the way. Makes it a pain to get underneath your bed in the compartment area! ","replyToPid":0}
发表于 2020-1-13 09:10:25 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"."}
发表于 2020-1-13 09:10:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"I saw a 40\" samsung for a little over $200 last time I was in the bestbuy and almost got it but I wasn't sure how much rocking the TV does while the truck is rolling down the road, is yours sturdy?","replyToPid":303404}
GMT+8, 2026-4-17 08:39 , Processed in 0.088544 second(s), 24 queries .
