查看: 251|回复: 13
Apparently I was blocked by TP by my previous title
 楼主| 发表于 2020-1-11 09:01:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"It's so sad that the post you put up gets blocked when they deem it offensive, when to everyone who is on this wouldn't consider the post offensive. Remember the 1st amendment?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-11 13:13:46 来自手机 | 显示全部楼层
682141 发表于 2020-01-11 02:06:02 Use memes like I do, bypasses the language filter, long press on your keyboard to get other language letters.
","text":"you need a long press on your esophagus","replyToPid":302123}
回复 支持 2 反对 2
发表于 2020-1-11 10:34:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trucker path was created by a h, omo ","replyToPid":0}
发表于 2020-1-11 22:16:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"the world is to PC today you say hello to someone it might offend them it is truly sad","replyToPid":0}
发表于 2020-1-11 11:49:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Silicon valley snowflakes are wreaking havoc on common sense.","replyToPid":0}
发表于 2020-1-11 13:20:21 来自手机 | 显示全部楼层
688068 发表于 2020-01-11 05:13:46 you need a long press on your esophagus
","text":"🤣🤣🤣","replyToPid":302196}
发表于 2020-1-11 10:05:03 来自手机 | 显示全部楼层
888230 发表于 2020-01-11 01:16:44 You weren't blocked. I did a DDOS attack to be a príck on TP.
","text":"Is true, can verify, I thought they'd finally rid me of posting, but thankfully its back.","replyToPid":302089}
 楼主| 发表于 2020-1-11 13:19:48 来自手机 | 显示全部楼层
346626 发表于 2020-01-11 04:13:17 Were you forced to change your name?
","text":"It was the only way to get back and post or see the responses from y'all ","replyToPid":302180}
发表于 2020-1-11 10:06:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Use memes like I do, bypasses the language filter, long press on your keyboard to get other language letters.","replyToPid":0}
发表于 2020-1-11 09:48:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"They don't appreciate a good conversation","replyToPid":0}
发表于 2020-1-11 13:12:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"bunch of pansies","replyToPid":0}
发表于 2020-1-11 09:14:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only those without power care about the First Amendment.","replyToPid":0}
发表于 2020-1-11 12:13:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Were you forced to change your name?","replyToPid":0}
GMT+8, 2026-4-18 21:26 , Processed in 0.137519 second(s), 24 queries .
