查看: 384|回复: 40
Flat planet.
 楼主| 发表于 2020-1-10 10:22:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"Who believes our planet is flat?  I am one of them, I do not believe that if the earth is a ball then there are people below that stand upside down just imagine it yourself.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-10 10:28:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have to get your 10hrs of rest right about now! ","replyToPid":0}
回复 支持 9 反对 0
发表于 2020-1-10 11:54:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well, thank goodness our scientific researchers, engineers, and lawmakers don’t build the structural laurels of our  society on some people’s um, “beliefs.” ","replyToPid":0}
发表于 2020-1-11 11:40:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"For the sake of debate, I’ll attest to something that I discovered on my own, without television, science, or prior knowledge. \n\nOn I-90 westbound, as you enter into Pennsylvania, there is a welcome center located on a high bit of land over looking Lake Erie. One day when I stopped for a rest, I was outside on the observation deck looking out on to the lake. I noticed two objects on the horizon light in color. After a few minutes of watching I determined that whatever it was was not moving. So I went back to my truck, got a pair of binoculars, and returned. It only took me a moment to realize what I was seeing was the top half of a pair of smoke stacks. \n\nAfter a quick look a google earth, I discovered that across the lake from the welcome center, in Canada, there is a coal fired steam plant along the shore. But, because of the curvature of the planet, I could only see the top half of the stacks. \n\nYou certainly have a right to believe in whatever you want, and I am not gonna down you for that. But the question invoked a memory from some years ago on one of my many trips to the area. Good day. ","replyToPid":0}
 楼主| 发表于 2020-1-10 14:03:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Let them show me online the Earth through the Hubble telescope. But NASA does not want to do this and shows some scraps","replyToPid":0}
发表于 2020-1-10 23:29:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"this is one thing a Vikings fan and a Packers fan can agree on.","replyToPid":301760}
发表于 2020-1-10 10:57:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"yep and every planet is round except this one 😂 just get a telescope and take a look in the night sky the earth is flat then it really must just go on forever or is there some magical transportation system at the edge that takes you to the other side of the flat planet","replyToPid":0}
发表于 2020-1-10 10:59:12 来自手机 | 显示全部楼层
886706 发表于 2020-01-10 02:36:19 Do you believe that at the bottom of the planet people walk upside down? answer question give you idea,not go personally did someone sleep 10 or not
","text":"Come on man,  🌎 ","replyToPid":301556}
发表于 2020-1-10 11:35:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s actually a disc, balanced on the backs of four elephants which in turn stand on the back of a giant turtle that swims through the cosmos. ","replyToPid":0}
发表于 2020-1-11 22:24:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Theres no dumber animal than a flat earther. Except maybe a poor Republican.","replyToPid":0}
发表于 2020-1-11 11:19:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dude, your definitely high if you think the earth is flat","replyToPid":0}
 楼主| 发表于 2020-1-10 10:31:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm home taking my rest dont worry","replyToPid":0}
 楼主| 发表于 2020-1-10 10:36:19 来自手机 | 显示全部楼层
885206 发表于 2020-01-10 02:28:27 You have to get your 10hrs of rest right about now!
","text":"Do you believe that at the bottom of the planet people walk upside down? answer question give you idea,not go personally did someone sleep 10 or not","replyToPid":301553}
发表于 2020-1-10 11:51:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤦🏻‍♂️","replyToPid":0}
发表于 2020-1-10 11:59:57 来自手机 | 显示全部楼层
","text":"agreed","replyToPid":301553}
GMT+8, 2026-4-18 23:13 , Processed in 0.122201 second(s), 24 queries .
