查看: 137|回复: 3
A question for y’all
 楼主| 发表于 2020-1-9 11:23:38 来自手机 | 显示全部楼层 |阅读模式
{"text":"when you apply to a new company can that company you are applying to see all the regular and trucking jobs you have ever worked even if you didn’t list them in your application? Obviously you are suppose to list them all per DOT requirements but I’m only curious if you forgot about a job and didn’t list it will they find it somehow somewhere in a background check ?  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-9 23:09:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"sounds like you are kinda nervous about them finding something out 🤷🏻‍♂️","replyToPid":0}
发表于 2020-1-9 23:18:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"just list them the best you can,  I have forgotten some employers and the dates,  usually when your new employer runs the dac report, it will have all the companies you drove for listed.  they can help you fix your application if its incorrect.  good luck .","replyToPid":0}
发表于 2020-1-9 23:29:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can also get a copy of your DAC.  As long as they match, nothing else matters.\n\nAnd the ten year thing only applies to dot regulated jobs.  Flipping burgers at the Golden Arches 8 years ago doesn’t matter.  You still need to list it, but no one is looking at those.","replyToPid":0}
GMT+8, 2026-4-18 03:23 , Processed in 0.076015 second(s), 24 queries .
